Any problems casting as Ipp32f*?
lkeene
Hello all,
I'm getting strange crashes when deallocating memory and it occured to me it may be the way I'm casting my buffers to the IPP functions. For example, I'm allocating memory as follows:
float* SourceBuffer = (float*)_mm_malloc(BufferSize, 16);
float* TargetBuffer = (float*)_mm_malloc(BufferSize, 16);
etc...
When passing to an IPP function, I cast as follows:
ippResult =ippsAbs_32f((const Ipp32f*)SourceBuffer, (Ipp32f*)TargetBuffer, NumElements);
Is this kosher?
Vladimir_Dudnik
correct use of _mm_malloc function should not cause issues. Are you sure you calculate correct BufferSize? It should be something like BufferSize = NumElements * sizeof(Ipp32f)
Vladimir
lkeene
I'm actually calculating BufferSize as (NumElements * 4). Ipp32f is 32-bits, no?
Vladimir_Dudnik
Yes, Ipp32f is 4 bytes single precision floating point data type so your calculationshould be fine. Could you please check that using IPP memory allocation (which provide alignment on 32-bytes boundary) does not cause issue?
You can try either ippMalloc(NumElements*sizeof(Ipp32f)) or ippsMalloc_32f(NumElements) instead of _mm_malloc call. Note you will need to use ippFree or ippsFree accordingly.
Vladimir
lkeene
Using the IPP allocations has no effect on the error. Still crashing at "_mm_free(Buffer)". Some buffers crash upon deallocations whereas others don't. I've noticed that the ones that are problematic are implicated with functions that require packing/unpacking, and these happen to be the ones where I was a little unsure of the arguments. For example, I've got the following:
int columns = 32;
int rows = 32;
IppiSize sizeOb;
sizeOb.height = rows;
sizeOb.width = columns;
int BytesPerScanline = columns * 4;
int BufferSize = rows * columns * 4;
IppiFFTSpec_R_32f* fftSpec;
IppResult = ippiFFTInitAlloc_R_32f(&fftSpec, Xorder, Yorder, IPP_FFT_DIV_FWD_BY_N, ippAlgHintFast);
int bufferSize;
IppResult = ippiFFTGetBufSize_R_32f(fftSpec, &bufferSize);
Ipp8u* ExternalFFTBuffer = (Ipp8u*)ippMalloc(bufferSize);
float* TempBuffer = (float*)_mm_malloc(BufferSize, 16);
float* UnpackBuffer = (float*)_mm_malloc(BufferSize * 2, 16);
// Load source buffer with data...
// Forward FFT:
ippResult = ippiFFTFwd_RToPack_32f_C1R((const Ipp32f*)SourceBuffer, BytesPerScanline, (Ipp32f*)TempBuffer, BytesPerScanline, (const IppiFFTSpec_R_32f*)transformSpec, externalFFTBuffer);
// Unpack to complex array:
ippResult = ippiPackToCplxExtend_32f32fc_C1R((const Ipp32f*)tempBuffer, sizeOb, BytesPerScanline, (Ipp32fc*)UnpackBuffer, BytesPerScanline*2);
_mm_free(TempBuffer); // Crash -> "CRT detected that the application wrote to memory after end of heap buffer"
_mm_free(UnpackBuffer); // Crash -> "CRT detected that the application wrote to memory after end of heap buffer"
This looks good to me. Have I misunderstood something in the docs?
Vladimir_Dudnik
Did you get my point about using appropriate ipp memorydeallocation function when you use ipp memory allocation ?
Vladimir
lkeene
Yes, sorry...I meant to say still crashing even when using "ippsMalloc_32f /ippsFree()".
Vladimir_Dudnik
Well, did you pay attention to different size of source and destination images for ippiPackToCplxExtend function you use? According to IPP documentation:
PackToCplxExtend
Converts an image in packed format to a complex data image.
Syntax
IppStatus ippiPackToCplxExtend_32s32sc_C1R(const Ipp32s* pSrc, IppiSize srcSize, int srcStep, Ipp32sc* pDst, int dstStep);
IppStatus ippiPackToCplxExtend_32f32fc_C1R(const Ipp32f* pSrc, IppiSize srcSize, int srcStep, Ipp32fc* pDst, int dstStep);
Parameters
pSrc
Pointer to the source image ROI.
srcSize
Size in pixels of the source image ROI.
srcStep
Distance in bytes between starts of consecutive lines in the source buffer.
pDst
Pointer to the destination image buffer.
dstStep
Distance in bytes between starts of consecutive lines in the destination image buffer.
Description
The function ippiPackToCplxExtend is declared in the ippi.h file. It operates with ROI (see Regions of Interest in Intel IPP).
This function converts the source image pSrc in RCPack2D format to complex data format and stores the results in pDst, which is a matrix with complete set of the Fourier coefficients. Note that if the pSrc in RCPack2D format is a real array of dimensions (NxM), then the pDst is a real array of dimensions (2xNxM). This should be taken into account when allocating memory for the function operation.
Vladimir
lkeene
Yes. Please note my posted code has:
TempBuffer = (float*)_mm_malloc(BufferSize, 16); // (M x N x NumBytesInFloat)
UnpackBuffer = (float*)_mm_malloc(BufferSize * 2, 16); // (M x N x 2 x NumBytesInFloat)
Anyway, I may have misunderstood the documentation regarding one crucial aspect. Consider the following prototype:
IppStatus ippsConj_32fc_I(Ipp32fc* pSrcDst, int len);
where the docs state "int len =Number of elements in the vector." This was a little ambiguous. I interpreted it as the sum of real and imaginary elements in the vector, i.e. I have
int rows = 32;
int columns = 32;
int NumberOfValues = rows * columns;
int NumberOfComplexElements = NumberOfValues * 2;
ippResult = ippsConj_32fc_I((Ipp32fc*)UnpackBuffer, NumberOfComplexElements);
Could I have misunderstood something here?
Vladimir_Dudnik
IPP functions working with complex data type conisder elements as complex elements, so you should specify number of complex elements for ippsConj_32fs_I function as a lenght parameter (not sum of real and image parts).
Vladimir
