BGRtoLAB wrong formula specified?
Loos__Stefan
HI
I have a question about the function BGRtoLAB
for LAB, there is a case condition specified in the Manual:
L = 903.3 * (Y/Yn)1/3. for Y/Yn 0.008856
Now, if I take the border case ,  0.008856^(1/3) is ~0.207,   ->  mult  903.3   = ~187
This value is converted to range of 0..255 by factor 2.55, so we get 476 which is way out of range.
Actually i run into this condition (Y/Yn 0.008856) for values like  R=0, G=0, B=10 which is pretty dark, L should be Close to 0 also
So what is wrong with your formulas?
thx & BR
Stefan
Loos__Stefan
Hi again
found some other formulas. I think it should be without Exponent ^(1/3) like in the f(t) formulas:
L = 903.3 * (Y/Yn). for Y/Yn ≤ 0.008856
as 903 is the factor 7.787*116
Jing_Xu
Thank you for reporting the issue,
We will investigate it.
Loos__Stefan
Yes, have a look. the code is ok, the results are ok of the ipp, just the doku
also in the f(t) formula something is wrong, as f(t) is around ~1 you probably won´t substract 16 and multiply later the result .... . It´s all messed up
Jing_Xu
What is "doku"? Besides, what does "the code is ok, the results are ok of the ipp" mean? Your program works OK with the IPP function BGRtoLab?
Is this a “theoretical” question? Or could you provide us with a test image and a sample code that can reproduce the problem that you encountered, please?
Loos__Stefan
Yes, the code works, the results are ok
only the documentation (docu, doku) is horribly wrong (the named formulas)
BR
Jing_Xu
OK. Got it. Thank you for reporting the issue.
