Bug in mp3enc_api_fp.c
m3driver
The memory for state->pMDCTSpec36 & state->pMDCTSpec12 is allocated using ippsMDCTFwdInitAlloc_32f() and should be freed in mp3encClose_layer3() using ippsMDCTFwdFree_32f() not ippsFree()
This was found in 5.3.4.087
Vladimir_Dudnik
Thanks, I'll let development team to know about your report. By the way, did you check IPP 6.0 beta where this issue might be already solved?
Vladimir
m3driver
Quoting - vdudnik
Vladimir
No, the beta is considerably different in structure. Is it safe to swictch the beta yet? If not, when is release anticipated?
m3driver
I compiled the 6.0 beta and found it has a different memory leak - the psychoacoustic_block.IIRfilterState is not being free'd. mp3encClose() needs to change to:
[cpp]MP3Status mp3encClose(MP3Enc *state)
  if (NULL == state){
    return MP3_OK;
  switch(state->com.header.layer) {
      case 1:
        break;
      case 2:
        break;
      case 3:
	   int i;
	  mp3encClose_layer3(state);
	  for (i=0; i<4; i++)
	     ippsIIRFree_32f(state->psychoacoustic_block.IIRfilterState);
       break;
      default:
        break;
  return MP3_OK;
}[/cpp]
