6825 Discussions
Building video_enc_con_wce4.cpp under MS VS 2005?
midshipman
Hi,all
Is it possible to use IPP under MS VS 2005? Or maybe better to use it under 2003 or VC6 ?
Anyway,when I tried to compile video_enc_con_wce4.cpp,I got :
video_enc_con_wce4 : error PRJ0004 : Could not generate command line for the 'VCCLCompilerTool' tool.
Can anyone tell me where is wrong ?
Any help appreciated !!
Vladimir_Dudnik
probably younoticed that we provide some build scripts with IPP media sample. Do you have problems with build of IPP media sample?
Vladimir
midshipman
Thanks for your reply ! you rfast :)
I can build all the samples using ur scripts. Then I created a new project for WM2005 under VS2005,and got this problem.
midshipman
Well,Ifixed the problem:)
just creating a new projects of 'smart device' instead of creating the projects from existing code.
Buta after some steps,now I have 7 errors like:
error LNK2019: unresolved external symbol "public: int __cdecl UMC::H264EncoderParams::ReadParamFile(wchar_t *)"
I think I should add h264_enc.lib to 'additional dependencies' through linker->input.But it doesn't work,strange......
Any point to this problem ?
Thanks a lot !
Vladimir_Dudnik
Probably you also should specify to linker path where to look for additional libraries
midshipman
I already did it,that's why so strange......
