Calling IPP from Fortran
eos_pengwern
I'd like to access a few IPP (Intel Performance Primitives) functions from my Fortran code, and as there doesn't seem to be a standard Fortran interface to them I began to generate my own. As for the time being I'm only interested in two functions, my first attempt at writing the required module is short enough to reproduce here in full:
[fortran]module IPP
    use, intrinsic :: iso_c_binding
    implicit none
    integer, parameter :: IPPI_INTER_NN      = 1
    integer, parameter :: IPPI_INTER_LINEAR  = 2
    integer, parameter :: IPPI_INTER_CUBIC   = 4
    integer, parameter :: IPPI_INTER_SUPER   = 8
    integer, parameter :: IPPI_INTER_LANCZOS = 16
    type, bind(c) :: IppiRect
        integer :: x
        integer :: y
        integer :: width
        integer :: height
    end type IppiRect
    type, bind(c) :: IppiSize
        integer :: width
        integer :: height
    end type IppiSize
    interface
        function ippiResizeGetBufSize(srcROI, dstROI, nChannels, interpolation, bufsize) bind(c)
                                                   ! N.B. 'bind(c)' implies 'external'
            type(IppiRect), intent(in) :: srcROI, dstROI
            integer, value :: nChannels, interpolation
            integer, intent(out) :: bufsize
            integer :: ippiResizeGetBufSize
        end function ippiResizeGetBufSize
    end interface
interface function ippiResizeSqrPixel_64f_C1R(pSrc, srcSize, srcStep, srcROI, pDst, dstStep, dstROI, & xFactor, yFactor, xShift, yShift, interpolation, pBuffer) bind(c) ! N.B. 'bind(c)' implies 'external' real(c_double), intent(in), dimension(srcROI%width, srcROI%height) :: pSrc type(IppiSize), value :: srcSize integer, value :: srcStep type(IppiRect), value :: srcROI real(kind(1d0)), intent(out), dimension(dstROI%width, dstROI%height) :: pDst integer, value :: dstStep type(IppiRect), value :: dstROI real(c_double), value :: xFactor, yFactor, xShift, yShift integer, value :: interpolation character, intent(inout), dimension(1) :: pBuffer integer :: ippiResizeSqrPixel_64f_C1R end function ippiResizeSqrPixel_64f_C1R end interface end module IPP[/fortran]
The reasons that this doesn't work have surprised and, so far, baffled me. The interface blocks don't seem to be able to make use of the derived types which are defined immediately above them in the same module. Specifically, here are my compilation error messages:
[bash]IPP.f90(38): error #6457: This derived type name has not been declared.   [IPPIRECT]
IPP.f90(35): warning #6717: This name has not been given an explicit type.   [SRCROI]
IPP.f90(35): warning #6717: This name has not been given an explicit type.   [DSTROI]
IPP.f90(54): warning #6717: This name has not been given an explicit type.   [SRCROI]
IPP.f90(54): error #6535: This variable or component must be of a derived or structure type   [SRCROI]
IPP.f90(54): error #6460: This is not a field name that is defined in the encompassing structure.   [WIDTH]
IPP.f90(54): error #6223: A specification expression is invalid.   [WIDTH]
IPP.f90(54): error #6460: This is not a field name that is defined in the encompassing structure.   [HEIGHT]
IPP.f90(54): error #6223: A specification expression is invalid.   [HEIGHT]
IPP.f90(55): error #6457: This derived type name has not been declared.   [IPPISIZE]
IPP.f90(57): error #6457: This derived type name has not been declared.   [IPPIRECT]
IPP.f90(58): warning #6717: This name has not been given an explicit type.   [DSTROI]
IPP.f90(58): error #6535: This variable or component must be of a derived or structure type   [DSTROI]
IPP.f90(58): error #6223: A specification expression is invalid.   [WIDTH]
IPP.f90(58): error #6223: A specification expression is invalid.   [HEIGHT]
IPP.f90(60): error #6457: This derived type name has not been declared.   [IPPIRECT]
IPP.f90(54): warning #6717: This name has not been given an explicit type.   [WIDTH]
IPP.f90(54): warning #6717: This name has not been given an explicit type.   [HEIGHT]
IPP.f90(50): warning #6717: This name has not been given an explicit type.   [SRCSIZE][/bash]
So far there's nothing IPP-specific in any of this - I haven't tried linking the libraries themselves in yet - so these are entirely generic Fortran errors. I would expect this to compile though, so what have I missed?
Stephen.
IanH
Interface blocks are a totally different scope to the program unit that hosts them. Unlike internal procedures or module procedures, they don't inherit by host association any of the things that are defined by the host. (They also don't inherit the implicit typing rules of the host - if you don't specify IMPLICIT NONE inside an interface body in an interface block then ye-olde fortran implicit typing is in effect in that interface body.)
To bring a type (or parameter, etc) in from the parent scope you can either repeat the definition of the the type definition (only if it is a BIND(C) or SEQUENCE type); or put the type definition in a separate module and then USE that module inside the interface body (also applicable to the entities from ISO_C_BINDING) and the parent scope; or your can use the IMPORT statement introduced with Fortran 2003.
For example:
[fortran]   interface
            import :: IppiRect
            implicit none
    end interface
[/fortran]
On a separate note - be mindful that without a NAME= clause the binding label for a procedure will be an all lower version of your procedure name - not the mixed case that you've used in your function statements. I don't know whether you want the mixed or lower case variant.
IanH
For example:
[fortran]   interface
            import :: IppiRect
            implicit none
    end interface
[/fortran]
eos_pengwern
Thank you Ian. That was the key to it.
Here is the version that compiles without error:
[fortran]odule IPP
    implicit none
        integer :: x
        integer :: y
        integer :: width
        integer :: height
    end type IppiRect
        integer :: width
        integer :: height
    end type IppiSize
    interface
        function ippiResizeGetBufSize(srcROI, dstROI, nChannels, interpolation, bufsize)             &
                                      bind(c, name='ippiResizeGetBufSize')
            import :: IppiRect
            implicit none
    end interface
    interface
                                            xFactor, yFactor, xShift, yShift, interpolation, pBuffer) &
                                            bind(c, name='ippiResizeSqrPixel_64f_C1R')
            import :: IppiRect, IppiSize
            implicit none
            real(c_double), intent(out), dimension(dstROI%width, dstROI%height) :: pDst
            real(kind(1d0)), value :: xFactor, yFactor, xShift, yShift
    end interface
All I have to do now is to get the linking right, and check that it all works.
Stephen.
eos_pengwern
"All I have to do now is to get the linking right, and check that it all works."
(hollow laughter)
Sometimes, you just know you're on a hiding to nothing. Nothing I've tried so far has enabled my Fortran linker to find the IPP functions, and even Intel Premier Support say "sorry, we don't support this". There are in existence some examples of IPP cryptography functions being called from Fortran without ISO_C_BINDING but with many lines of !DEC$ ATTRIBUTES and !MS$ATRIBUTES declarations(which I've never seen before), but I haven't been able to imitate these successfully.
I guess it's time to find another solution, without the IPP.
TimP
ipp is an optional component of icc installation or icc redistributable library. If you have the same version of icc and ifort, the environment script should put the ipp libraries on the search path, so -lipp..... should find them (in the path under /ipp/lib in the directory which contains the ifort /lib/).
There's no move to support .mod files to take care of the ISO_C INTERFACE or automatic choice of the relevant ipp libraries under ifort, so this involves significant hassle.
eos_pengwern
Sadly yes... I know where the IPP .lib and .dll files are in the path, as I have another C++ application that uses them successfully. I think the problem from Fortran is entirely one of interface and/or calling convention, so that the linker doesn't recognise the IPP function in the library on the basis of the description provided in the Fortran interface block.
Wendy_Doerner__Intel
Valued Contributor I
You should in theory be able to call ipp functions from Fortran just like you make an interlanguage call from Fortran to C routine with parameters. I have checked with the premier support manager for IPP and she suggested to send you to their forum in case they have some more concrete suggestions now that you have working Fortran code.
There is a cryptography example that shows how to call IPP from Fortran (you may have seen this).
But ultimately you need to figure out based on the IPP definition files for the parameters how to specify them in the FORTRAN for MIxed Language calls. The section of the Fortran Documentation that discusses this is:
Mixed Language Programming
Wendy
Attaching or including files in a post
eos_pengwern
I tried writing a separate C DLL with simplified interfaces to the IPP, and although I could link to the IPP from the C library I still couldn't link to the C library from Fortran, so I don't know what I did wrong. I must be getting my _cdecls and _stdcalls in a twist.
I have come up with a solution that works for me, for now, though. As my Fortran code is a library that is called from a C++ application which itself makes use of IPP routines, I have put the C functions with simplified interfaces into my main application code, and then passed pointers to them as 'callbacks' alongside the other parameters being passed to the Fortran routines. When the Fortran routines need to access the IPP, they just call the callback functions they've been provided with. This works fine. Although it makes the source code a little more convoluted than I'd like, ithas the big advantage thatI don't need to touch my makefiles.This is useful as this suite gets compiled on various different platforms. It also confirms that my C interfaces are fine, so there's obviously some other reason why I can't seem to do the linking from Fortran.
Stephen.
IanH
Quoting eos pengwern
I know nothing of IPP, but this C interface layer seems a reasonable approach. Getting Fortran code that you control to talk to C code that you control should be relatively straight forward. Perhaps post the C function declaration and C compiler options along with what you used to define the interface on the Fortran side.
Lorri_M_Intel
Yeah, you're going to have to use C++ as the intermediary.
The IPP routines all have C++ interfaces, and that's not covered by ISO_C_BINDING, because of the name
mangling among other things.
-- Lorri
eos_pengwern
Ah yes, that would explain the difficulty with the linking!
Stephen.
