Calling IPP from Microsoft Visual C# 2008
Ajay_N_
I dunno if this is a most commonly asked question , but can some one temme the exact procedure to call IPP from MS Visual C# 2008 ?
AJ
Vladimir_Dudnik
Hi AJ,
we provide even more. You can find an example code how to call IPP functions in C#. Please download IPP sample package and take a look at it.
Vladimir
Ajay_N_
Thank you for your reply !
I have downloaded ipp-samples ver 6.0.0.79 , in that I cant find any thing wrt to C# , so does that mean an extensive support for C# is a new feautre in IPP ? Also does Intel Parallel studio support C# or only Visual C++ ?
THanks agian
AJ
pvonkaenel
New Contributor III
THanks agian
AJ
It's in a strange place, but take a look at the C#_image.pdf doc in the ipp-sampleslanguage-interfacedotnet-cppdoc directory.
PEter
Ying_S_Intel
THanks agian
AJ
AJ,
The current Intel Parallel Studio supports C/C++, however the Intel IPPlibraires in Parallel Composer can be called in C# environment. The location Peter pointed outabove is the right location from Intel IPP sample.
Additionally, if you install the latest version of Intel Parallel Studio, you can also find this C# sample under directory at C:Program FilesIntelParallel StudioComposerSamplesen_USIPPipp-samples-language.zip
Another reference you may check is a KB about how Intel C/C++ compiler addresses managed code support.
By the way, were in the process of identifyingfeaturesforC++ /C# support in Intel IPP and would like your input. Please take a quick survey here.
Thanks again for your interestin Intel Software tools.
Ying S
Intel Corp.
