6845 Discussions
Can Mpeg2FrameConstrutor detect changes in aspect ratio? solved!
elsparro
Edit: Solved by using GetInfo() from the decoder.
I have a live stream that changes aspect ratio on-the-fly, I try to detect that with following the code but it don't work.
m_framer are an instance of Mpeg2FrameConstructor.
UMC::VideoStreamInfo* vinfo = (UMC::VideoStreamInfo*) m_framer.GetInfo()->m_pStreamInfo;
if (vinfo->videoInfo.m_iSAWidth  != lastSAWidth) {
This is done for every frame from the framer.
Is this supposed to work or are there a better way?
Any help is appriciated
