Can't build Intel® IPP 7.1 Samples
Genady_Malinsky
I download the new Intel IPP 7.1 and ipp-samples.7.1.1.013 also I download CMake* 2.8.8 and  ActiveState* perl.
My OS is Win7  32 bit i5.
When I tried to compile the audio-video-codecs I encountered an Error:
C:\IPP 7.1.1\ipp-samples.7.1.1.013\builder>perl build.pl --cmake=audio-video-cod
ecs,ia32,vc2010,s,st,release
CNot searching for unused variables given on the command line.
Make Error: The source directory "C:/IPP 7.1.1/ipp-samples.7.1.1.013/__cmake/audio-video-codecs.ia32.vc2010.s.st/7.1.1/ipp-samples.7.1.1.013/sources/audio-video-codecs" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
Can someone please assist?
Genady.
Ying_H_Intel
Hi Genady, I upload the project you asked by premier. Just a quick idea, the directory structure seems do a trick. How about keep the initial structure: l C:\IPP 7.1.1\w_ipp-samples_p_7.1.1.013\ipp-samples.7.1.1.013\builder ? Best Regards, Ying
Sergey_K_Intel
Hi Genady, Please, make sure that there are no spaces in directory names. Buil.pl doesn't like them. Regards, Sergey
Ying_H_Intel
upload the two msvc2010 projects with the post. As the project is using absolute path, please 1) create a directory under C: C:\Temp. 2) extract w_ipp-samples_p_7.1.1.013 there. The directory structure is like C:\Temp\w_ipp-samples_p_7.1.1.013\ipp-samples.7.1.1.013 3) extract the __cmake.zip C:\Temp\w_ipp-samples_p_7.1.1.013\ipp-samples.7.1.1.013\__cmake
Serhat_T_
I cannot create VS 2010 solution with cmake.
Folder: /ipp-samples.7.1.1.013/sources/image-processing/application/ippidemo
It gives this error:
CMake Error at CMakeLists.txt:20 (make_executable):
Unknown CMake command "make_executable".
Anton_S_Intel
Genady, please make sure that you have no spaces in paths. This is know issue and will be fixed.
Serhat, can you please upload full log of build.pl run? You should run command like "build.pl -cmake=..... > log.txt 2>&1"
