Cannot link to IPP framework in Mac OS X
jlafleur
I am trying to build a test application to try out IPP, but it seems like the Intel_IPP file in the Intel_IPP.framework framework is invalid, and only contains a single line of ASCII text...
[bash]mac:~/programming/cpp/icc_test$ icpc -framework Intel_IPP main.cpp -o icc_test
ld: warning: in /Library/Frameworks//Intel_IPP.framework/Intel_IPP, file was built for unsupported file format which is not the architecture being linked (x86_64)
mac:~/programming/cpp/icc_test$ file /Library/Frameworks/Intel_IPP.framework/Intel_IPP
/Library/Frameworks/Intel_IPP.framework/Intel_IPP: symbolic link to `Versions/Current/Intel_IPP'
mac:~/programming/cpp/icc_test$ file /Library/Frameworks/Intel_IPP.framework/Versions/Current/Intel_IPP
/Library/Frameworks/Intel_IPP.framework/Versions/Current/Intel_IPP: ASCII text
mac:~/programming/cpp/icc_test$ cat /Library/Frameworks/Intel_IPP.framework/Versions/Current/Intel_IPP
../../build/osx_fw_full/build/Release/Intel_IPP.framework/Versions/Current/Intel_IPP
[/bash]
I have version 5.3.4.075 of IPP installed.
Thanks in advance for any help!
Ying_S_Intel
Please take a look at " Building Intel IPP for Mac OS" http://software.intel.com/en-us/articles/intel-integrated-performance-primitives-for-mac-os-how-to-link-to-the-intel-ipp-for-mac-os-x-libraries-in-application/ to see if it can help.
By the way, are you aware the latest IPP version 6.1 update 4 available via Intel Compiler Prov11.1for Mac OS? http://software.intel.com/en-us/articles/which-version-of-ipp--mkl--tbb-is-installed-with-intel-compiler-professional-edition/ ?
Ying
jlafleur
Thank you for your answer; I found a solution to this problem at the same time as I found the solution to an other of my problems:
http://software.intel.com/en-us/forums/showthread.php?t=72383
Thanks!
