6797 Discussions
Change H.264 encoder bitrate in the time of encoding
evgeny777
Hi, all!
I'm developing VoIP application using Intel IPP H.264 encoder/decoder. I want my application to adapt to
current network conditions, so it can dynamically change bitrate of encoded H.264 stream. For exampleapplication can
start with relatively low bitrate (100 Kbps) and if user have plenty of available bandwidth then I want to increase encoder
bitrate. Can I make SetParams() call while encoding? Or I should create another encoder instance to accomplish this task?
Emmanuel_W_
Quoting - evgeny777
Hi, all!
Calling SetParam is better than reinitializing the encoder (this avoid generating an IDR) but the current ofSetParam implementation is not great in my opinion. The rate controller is reinitialized altogether which can cause temporary overshoot/undershoot which is not ideal for a VoIP application.
Emmanuel
Emmanuel_W_
Quoting - evgeny777
Hi, all!
Emmanuel
