Compile error with gcc on linux
herrpi
Hey everyone,
I'm desperately trying to compile some of the audio-video-codecs samples on a Debian system with gcc. The intention is to get an H.264 encoder to run on an arm-based embedded system. I use Intel IPP v.60 for Linux OS.
For some first tests I'm trying just to compile the "umc_video_enc_con" on my local PC.
The pre-compiled samples are working just fine! I was able to encode a YUV raw video file as H.264 and play it again with the help of "simple_player".
How can I compile these samples with gcc??
I get many error messages, among others: (I typed 'gcc video_enc_con.cpp')
.... error: utils.h: No such file or directory
.... error: vm_time.h: No such file or directory
and so on!!
I've already tried to specify the include files by command line options but I guess there has to be some more professional solution!
Thanks for every advice!
-Simon.
Vladimir_Dudnik
Simon,
please check first if your target platform is listed in the list of supported IPP platforms.
Vladimir
herrpi
Vladimir,
yes, this could indeed be my problem! My target platform (ARM architecture) seems not to be supported by the IPP...
Well, thanks anyway!
-Simon.
