Crash bug in the rtp_amr_payload.cpp file ?
free1006
The IPP 7.0 update 5.
File: rtp_amr_payload.cpp:
#define AMR_NB_SID_RTP_FT 8
#define AMR_WB_SID_RTP_FT 9
#define AMR_UNTR_RTP_FT 15
static Ipp32s *AMR_NB_nOrderMaps[8];
static Ipp32s *AMR_WB_nOrderMaps[9];
static Ipp32s AMR_WB_FrameLenBits[10];
static Ipp32s AMR_NB_FrameLenBits[9];
In the function "GetBitReordersTable" will cause crash:
} else if((frametype==1)||(frametype==2)){
if(m_CodecType==NB) {
ft = AMR_NB_SID_RTP_FT;
} else {
ft = AMR_WB_SID_RTP_FT;
} else {
ft = AMR_UNTR_RTP_FT;
*pOrderMap = AMR_NB_nOrderMaps[ft];
*FrameLenBits = AMR_NB_FrameLenBits[ft];
} else {
*pOrderMap = AMR_WB_nOrderMaps[ft];
*FrameLenBits = AMR_WB_FrameLenBits[ft];
if the frametype is not 1 and 2, the "ft" value is AMR_UNTR_RTP_FT(15), The AMR_NB_nOrderMaps, AMR_NB_FrameLenBits, AMR_WB_nOrderMaps, AMR_WB_FrameLenBits size all are less than AMR_UNTR_RTP_FT.
It will got crashed ?
Igor_B_Intel1
Thank you for the report. This is actually just reading outside owned memory because the loaded data doesn't used.Yes, this is not good idea and crash duringmemory reading is possible in some cases.
We'llfix it in the next IPP releases.
Igor S. Belyakov
SergeyKostrov
Valued Contributor II
Igor S. Belyakov
This is simply to confirm that IPP v5.3.083 has the same problem ( at least 5 years old! )with the function
'GetBitReordersTable'.
