I installed Trial Composer 15 Desktop and IPP and Cryptography lib 8.2. I have found below code. I run the code, there is no compilation error but there are four link error like unresolved external symbol. I searched some issues. Issues say that you must add lib called ippid.lib, libemerged ext. but there is no these libraries. How can I solve this problem.
1>IntelRijndael.obj : error LNK2019: unresolved external symbol _ippsRijndael128GetSize@4 referenced in function _main
1>IntelRijndael.obj : error LNK2019: unresolved external symbol _ippsRijndael128Init@12 referenced in function _main
1>IntelRijndael.obj : error LNK2019: unresolved external symbol _ippsRijndael128EncryptCTR@24 referenced in function _main
1>IntelRijndael.obj : error LNK2019: unresolved external symbol _ippsRijndael128DecryptCTR@24 referenced in function _main
1>D:\RijndaelRefactoring\IntelDeneme\Debug\IntelRijndael.exe : fatal error LNK1120: 4 unresolved externals
Code:
// size of Rijndael-128 algorithm block is equal to 16
const int aesBlkSize = 16;
// get the size of the context needed for the encryption/decryption operation
int ctxSize;
ippsRijndael128GetSize(&ctxSize);
// and allocate one
IppsRijndael128Spec* pCtx = (IppsRijndael128Spec*)( new Ipp8u [ctxSize] );
// define the key
Ipp8u key[16] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,
0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15};
// and prepare the context for Rijndael128 usage
ippsRijndael128Init(key,IppsRijndaelKey128, pCtx);
// define the message to be encrypted
Ipp8u ptext[] = {"quick brown fox jupm over lazy dog"};
// define an initial vector
Ipp8u crt0[aesBlkSize] = {0xff,0xee,0xdd,0xcc,0xbb,0xaa,0x99,0x88,
0x77,0x66,0x55,0x44,0x33,0x22,0x11,0x00};
Ipp8u crt[aesBlkSize];
// counter the variable number of bits
int ctrNumBitSize = 64;
// allocate enough memory for the ciphertext
// note that
// the size of the ciphertext is always equal to that of the planetext
Ipp8u ctext[sizeof(ptext)];
// init the counter
memcpy(crt, crt0, sizeof(crt0));
// encrypt (CTR mode) ptext message
// pay attention to the 'length' parameter
// it defines the number of bytes to be encrypted
ippsRijndael128EncryptCTR(ptext, ctext, sizeof(ptext),
pCtx,
crt, ctrNumBitSize);
// allocate memory for the decrypted message
Ipp8u rtext[sizeof(ptext)];
// init the counter
// decrypt (ECTR mode) ctext message
// it defines the number of bytes to be decrypted
ippsRijndael128DecryptCTR(ctext, rtext, sizeof(ptext),
pCtx,
delete (Ipp8u*)pCtx;
For this code example you need ippCP library that is not a part of trial version of Composer and should be installed separately. ippdi (data integrity) library doesn't have any relation to the code above.
regards, Igor
Thank you igor for your reply. I understand ippid.lib. When I installed parallel_studio_xe_2015_setup.exe, ipp installed and then I installed cryptography lib separately. I can see ipp folder in my installation folder in C drive. I can see ippcp.lib also. But I have taken unresolved externals symbol error like above. How can I solve this problem. I use vs studio 2012 and windows 7.
please show your Linker Command Line from your project Configuration Properties -> Linker - it should contain ippcpmt.lib
regards, Igor
I made below settings in vs 2012 but there are still link errors
Configuration Properties -> C/C++ ->Additional Include Directories : intel\Composer XE 2015\ipp\include;
Configuration Properties -> Linker ->Additional Library Directories : intel\Composer XE 2015\ipp\lib\intel64;
Configuration Properties -> Linker ->Input ippcore.lib;ippcp.lib;ippcpmt.lib
what kind of linking you need - static or dynamic? ippcpmt.lib is static merged library while ippcp.lib is a stub lib for dynamic linking. So I see you have both in the command line, while you use stub lib for ippcore library... I think there should be either ippcore.lib, ippcp.lib (for dynamic linking - you'll need then ippcore.dll and ippcp.dll for application run), or ippcoremt.lib, ippcpmt.lib for static linking, but not some mix of them.
regards, Igor
if you would like to link with static, you should link with: ippcpmt.lib ippcoremt.lib
if you would like to link with dynamic, you should link with: ippcp.lib ippcore.lib
You should not mix static and dynamic libraries in link command!
Pavel
I use dynamic link. I deleted ippcpmt.lib and there are only ippcp.lib ippcore.lib in linker input. My configuration is in below
What else should I do?
I guess you missed #include "ippcp.h"
I can compile your example without problems to add necessary includes:
#include <memory.h> #include <stdlib.h> #include "ipp.h" #include "ippcp.h" int main() { // size of Rijndael-128 algorithm block is equal to 16 const int aesBlkSize = 16; // get the size of the context needed for the encryption/decryption operation int ctxSize; ippsRijndael128GetSize(&ctxSize); // and allocate one IppsRijndael128Spec* pCtx = (IppsRijndael128Spec*)( new Ipp8u [ctxSize] ); // define the key Ipp8u key[16] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07, 0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15}; // and prepare the context for Rijndael128 usage ippsRijndael128Init(key,IppsRijndaelKey128, pCtx); // define the message to be encrypted Ipp8u ptext[] = {"quick brown fox jupm over lazy dog"}; // define an initial vector Ipp8u crt0[aesBlkSize] = {0xff,0xee,0xdd,0xcc,0xbb,0xaa,0x99,0x88, 0x77,0x66,0x55,0x44,0x33,0x22,0x11,0x00}; Ipp8u crt[aesBlkSize]; // counter the variable number of bits int ctrNumBitSize = 64; // allocate enough memory for the ciphertext // note that // the size of the ciphertext is always equal to that of the planetext Ipp8u ctext[sizeof(ptext)]; // init the counter memcpy(crt, crt0, sizeof(crt0)); // encrypt (CTR mode) ptext message // pay attention to the 'length' parameter // it defines the number of bytes to be encrypted memcpy(crt, crt0, sizeof(crt0)); ippsRijndael128EncryptCTR(ptext, ctext, sizeof(ptext), pCtx, crt, ctrNumBitSize); // allocate memory for the decrypted message Ipp8u rtext[sizeof(ptext)]; // init the counter memcpy(crt, crt0, sizeof(crt0)); // decrypt (ECTR mode) ctext message // pay attention to the 'length' parameter // it defines the number of bytes to be decrypted ippsRijndael128DecryptCTR(ctext, rtext, sizeof(ptext), pCtx, crt, ctrNumBitSize); delete (Ipp8u*)pCtx; return 0; }
Whatever I did, I can not run this code. I always take a link error. should I add to env. variables anyting.
Did you try to build exactly my example?
