DH Key Agreement with IPP Cryptography
legion
I need to generate private/public key pair using Diffie-Hellman Key Agreement scheme.
Domain parameters that I must use are stored in PKCS#3-defined format.
DHParameter ::= SEQUENCE {
prime INTEER, -- p
base INTEGER -- g
privateValueLength INTEGER OPTIONAL }
Therefore I have only a prime P and a generator G , as well as an optional bitlength of the private value L.
I'd like to ask if there's any way to set up a DLP cryptosystem using these parameters only?
All my current attempts failed - IPP seems to work with DH agreement scheme subgroups specifically, andthat require additional prime Q domain parameter that is not available (or is there any way to derive it from the above parameters?)
Any help would be greately appreciated....
Vladimir_Dudnik
you need to have all three parameters to build complete system. Usually, the third parameter is defined at system design stage and depend on required level of security.
Vladimir
