Decode JPEG 2000
CHETAN_SHINDE
Hello All,
I need help for migrating Decoding of JPEG 2000 IMAGE & DCT Decode.
I was using Intel Compiler 2011 (m_ccompxe_2011.13.380) and now I want to upgrade sources to Intel compiler 2018 (m_ccompxe_2018.3.039.dmg).
In older version we were using function ReadImageJPEG2000
Can someone help with some sample code for decoding JPEG 2000 image in latest version Intel IPP. (2018 Update 3).
Thank You
Chetan...
Pavel_B_Intel1
Hello Chetan,
unfortunately we deprecated support of image, audio and video codecs in the IPP 9.0 version. The modern IPP package contains only building blocks for image and signal processing, no any codecs any more.
Pavel
CHETAN_SHINDE
Thank You Pavel
From where can I get sample sources (w_ipp-ijg_p_8.0.0.005.zip) which I can try building using Intel(R) IPP 9.0 Legacy Libraries.
Gennady_F_Intel
Chetan, could you try to submit this issue to the Intel Online Service Center?
CHETAN_SHINDE
Actually I manage to update/run my IPP 7.0 samples using Intel IPP Legacy Libraries 9.0 with the help give in following documentation. Now my old code is running perfectly :).
https://software.intel.com/en-us/articles/how-to-build-former-intel-ipp-samples-with-ipp-90-legacy-libraries
