Default compression level in IPP zlib sample
Ryan_Wong
I noticed this code in the IPP ZLIB sample when comparing with the public zlib 1.2.5 source. Can anyone explain the significance of "avoiding" level 6? Thanks.
[cpp]#ifdef IPP_DEFAULT_COMPRESSION
    if ((level == Z_DEFAULT_COMPRESSION) || (level == 6)) level = 5;
#else
[/cpp]
Naveen_G_Intel
Hi Ryan Wong,
To match with Zlib library, IPP Zlib compression levels are changed since form IPP 7.0.
Now level 6 is default as in the Zlib, as Sergey said, to make it faster with a less degree ofcompression enforcing to level 5.
If you want to match as in the previous releases of IPP, just change configuration_table structure.
/* 6 */ {8, 16, 128, 128, deflate_slow},
/* 5 */ {8, 16, 32, 32, deflate_slow},
#else
if (level == Z_DEFAULT_COMPRESSION) level = 6;
#endif
New compression levels are described in the article.
http://software.intel.com/en-us/articles/ipp_zlib-change-the-default-compression-level-1/
Naveen Gv
SergeyKostrov
Valued Contributor II
Quoting Ryan Wong
Hi Rayn,
Here are some pieces to the "puzzle" I found in 'zlib.h':
#define Z_NO_COMPRESSION 0
#define Z_BEST_SPEED 1
#define Z_BEST_COMPRESSION 9
#define Z_DEFAULT_COMPRESSION (-1)
/* compression levels */
and
The compression level must be Z_DEFAULT_COMPRESSION, or between 0 and 9:
1 gives best speed, 9 gives best compression, 0 gives no compression at
all (the input data is simply copied a block at a time).
Z_DEFAULT_COMPRESSION requests a default compromise between speed and
compression ( currently equivalent to level 6 ).
By enforcing a value'5' a datacompression will be done a little bit faster with a less degree ofcompression.
It looks like a developer simply didn't want to allowa default compression level( -1 or 6 )at all.
Sergey
Naveen_G_Intel
Hi Ryan Wong,
#else
#endif
Naveen Gv
