Does IPP 7.0 support TIFF B&W format? Because when I use PICNIC.exe to open a B&W TIFF,it shows the MessageBox showing "Error Reading Tiff".
Also does IPP 7.0 support TIFF zip or jpeg compression format?
Can you provide the image?
Can you test with different .tif images, because it works fine with other .tiff images.
Naveen Gv
Quoting viviansuda
Quoting Chuck De Sylva (Intel)
as you can see from uic_tiff_dec.cpp:ReadHeader function TIFF decoder doesn't support any TIFF compressions other than tag=1 (uncompressed).
Regarding BW format, I see that UIC does not support it properly and appropriate error exit/diagnostics will be added.
There are no plans to extend TIFF support.
Sergey
I am curious... why did you create such a useless TIFF support in the first place?
As a simple and widely supported intermediate storage container.
Baseline TIFF reader must support at least the following:
- uncompressed
- CCITT Group 3 1-Dimensional Modified Huffman RLE
- PackBits
See here for a list of features that must be supported in a baseline implementation of TIFF codec:
http://en.wikipedia.org/wiki/Tagged_Image_File_Format#Compression
Additionally, most common use of TIFF in imaging software is with LZW compression. If at least LZW compression is not supported by the TIFF codec then it is completely useless.
See here for the list of compression formats and how often each one of them is used:
http://en.wikipedia.org/wiki/Tagged_Image_File_Format#TIFF_Compression_Tag
- uncompressed
- PackBits
Topic Options
