6827 Discussions
Erode3x3/Dilate3x3 inplace - Implementation for other platforms
mweissbach
Hello everybody
I want to implement functions for dilating and eroding _inplace_ an image with an 3x3 filterkernel. I used for computing in Intel machines the IPP 4.0 . Now I want to implement it for other architectures by hand in Ansi C. The problem is, that it seems to be impossible to do that inplace - without further dynamical allocation of memory beside the image itself.
Now I want to know, if someone had the same problem or provides a solution for this. How is it solved in the IPP internally?
Thanks a lot for your support
M.W.
Intel_C_Intel
Erosion/dilation for the rectangular kernel is separable. So you can do it as the separable convolution
Alexander
mweissbach
Alexander
Thanks a lot for you immediate answer. Since there is no filterkernel given in the IPP Manual/Reference (Version 4.1), it is hard to find the correct one, so that the results of the computing with IPP and Ansi-C without using IPP are equal. Is there a possibility to publish the filterkernels of the functions mentioned above?
M.W.
Intel_C_Intel
Erode3x3/Dilate3x3 use gray-scale image and binary kernel with all 1s. Ancor is in the center. For arbitrary binary kernel you could use general morphology function.
Alexander
