6845 Discussions
Error -213 While Calling ippiFilterBorderInit_64f
amini__roham
Greetings,
this is my first post in this forum so please bear with me. While exploring the FilterBorder family of functions, I used ippRndFinancial round mode with ippiFilterBorderInit_64f. However it returned error -213. My question is can ippRndFinancial be used with ippiFilterBorderInit_64f (the documentation did not mention anything regarding this)? Attached is my Test.cpp file.
  • OS Windows 10 Pro (64-bit)
  • Compilers and Libraries 2019.5.281
  • Microsoft Visual Studio Professional 2019
Gennady_F_Intel
thanks for the issue, we will check. Did you check if you see the same issue with ippRndZero or other modes?
amini__roham
Dear Gennady,
Yes i tried all rounding modes. Same error with ippRndZero.  However,the function executed successfully with ippRndNear.
Gennady_F_Intel
thanks, we will investigate the cause of the issue and keep you informed with the status.
Gennady_F_Intel
ipptypes.h defines status of this operations: ippStsRoundModeNotSupportedErr    -213 /* Rounding mode is not supported. */
What kind of rounding mode do you need for supporting this function?
Pavel_B_Intel1
thanks for reporting, yes, it is the problem in the IPP documentation and in the ippi.h header file. Actually this function supports only the ippRndNear mode. We will correct documentation. If you need supporting other round modes please submit an official request through https://supporttickets.intel.com/
Pavel
amini__roham
Dear Pavel and Gennady,
thanks for your replies. I decided to use ippRndNear rounding mode. While exploring the FilterBorder family of functions, I also observed that each kernel data type only supports certain image data types as shown below.
kernel data type    supported image data types
    ipp16s                   ipp8u, ipp16u, ipp16s
    ipp32f               ipp8u, ipp16u, ipp16s, ipp32f
    ipp64f                              ipp64f
Wrong combination of kernel data type and image data type results in error -59 (ippStsDataTypeErr). If this is indeed the correct behavior for this family of functions, I was unable to find any documentation about it as well. (as a suggestion, this information could be added to the documentation for the sake of completeness.)
thanks
Pavel_B_Intel1
This should help you: https://software.intel.com/en-us/ipp-dev-reference-filterborder
Pavel
