After downloading the free version of IPP 5.3.4 for ia32 linux, I can not open the tgz file, it is invalid format. I tried on different computers in the past couple days, same result. Please help.
we've just check Linux install package, it seems to be OK. I'd recommend you download it again.
There is comment from our engineer
Ive completed double check of downloading and unpacking 2572515057 338277211 l_ipp_ia32_p_5.3.4.080.tgz
CheckSum is OK
The root problem is huge file /l_ipp_ia32_p_5.3.4.080/install/install
(It takes about 3 minutes to unpack this file on quad core system)
But actually everything unpacks successfully and Ill be able to install and use IPP
Vladimir
I've downloaded many times but no luck. Can you provide the
SHA1SUM or other checksum for the file?
Topic Options
