FFT. Inconsistency of documentation or bug?
hatuey
About IPP ippsFFTFwd_R function -
If the external buffer is not specified (pBuffer is set to NULL), then the function itself allocates the memory needed for operation.
(C) Intel IPP developer reference, vol. 1: Signal Processing
Sorry, it's true? Look at this.
Code:
#include <stdio.h>
#include <ipp.h>
#include <ipps.h>
int main(void) {
int order, sizeFFTSpec, sizeFFTInitBuf, sizeFFTWorkBuf;
IppStatus initstatus, transformstatus;
float *pData = ippsMalloc_32f(1 << 16);
ippsZero_32f(pData, 1 << 16); // it does not matter
for (order = 4; order <= 16; order++) {
IppsFFTSpec_R_32f* pFFTSpec;
Ipp8u* pFFTSpecBuf, * pFFTInitBuf;
ippsFFTGetSize_R_32f(order, IPP_FFT_NODIV_BY_ANY,
ippAlgHintNone, &sizeFFTSpec,
&sizeFFTInitBuf, &sizeFFTWorkBuf);
pFFTSpecBuf = ippsMalloc_8u(sizeFFTSpec);
pFFTInitBuf = ippsMalloc_8u(sizeFFTInitBuf);
initstatus = ippsFFTInit_R_32f(&pFFTSpec, order, IPP_FFT_NODIV_BY_ANY,
ippAlgHintNone, pFFTSpecBuf, pFFTInitBuf);
if (initstatus == ippStsNoErr) {
transformstatus = ippsFFTFwd_RToCCS_32f_I(pData, pFFTSpec, nullptr);
printf("FFT order %d\t%s\n", order, ippGetStatusString(transformstatus));
else return -1;
ippsFree(pFFTSpec);
ippsFree(pFFTInitBuf);
return 0;
Output:
FFT order 4 ippStsNoErr: No errors
FFT order 5 ippStsNoErr: No errors
FFT order 6 ippStsNoErr: No errors
FFT order 7 ippStsNoErr: No errors
FFT order 8 ippStsNullPtrErr: Null pointer error
FFT order 9 ippStsNullPtrErr: Null pointer error
and so on
UPD
IPP 2021.1.1, static version, Windows 10, MS Visual Studio 2019, MS C++ Compiler. Both Win32 & x64 platforms.
Andrey_B_Intel
Hi Hatuey.
IPP FFT does not allocate memory internally anymore. So noticed lines in documentation is obsolete now. We will update documentation in one of the next IPP releases.
Thanks that you use IPP since 7.0 version.
Andrey
IPP
GouthamK_Intel
We are able to reproduce the same on our end, we are working on your issue internally and we will get back to you soon regarding the same.
Goutham
hatuey
Thanks comrade! Really now it is not so big problem for me, because now I am aware;-)
I can only add that somewhat earlier the behavior was corresponded to the documentation (IPP 7)
Andrey_B_Intel
Hi Hatuey.
Andrey
IPP
hatuey
Thanks Andrey!
Yes, updating the documentation would be useful to prevent problems with porting previously created applications, and in general.
With wishes of further success to the IPP team,
Hatuey
Gennady_F_Intel
we will keep this thread informed when the reference will be updated.
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
