Feature Request
detlef_stralaudynami
Hallo,
i would be nice, also getting the pid description inUMC::AudioStreamInfo, for exapmle PID = 1023, description= "MEPG(German)" , PID = 1024, descrption ="MPEG(english)" and so one.
Detlef
Ying_H_Intel
Hello detlef,
The PID should be come from MPEG standard,the header ofTransport stream (TS) packetsinclude such information.
For example, somesescription like
the PID is 13-bit value used to identify multi-plexed packets with mpeg2-TS.
most of decoder of TSshould can read such information or set it during produce a TS.
Ying
Sorry, maybe my feature request was descripted not enougth. I mean this structure:
typedefstructsAudioStreamInfo:publicStreamInfo
sAudioStreamInfo()
:channels(0),sample_frequency(0),bitrate(0),bitPerSample(0),duration(0.0),stream_type(UNDEF_AUDIO)
,stream_subtype(UNDEF_AUDIO_SUBTYPE),channel_mask(0),streamPID(0),is_protected(false),header(0)
Ipp32schannels;//(Ipp32s)numberofaudiochannels
Ipp32ssample_frequency;//(Ipp32s)samplerateinHz
Ipp32ubitrate;//(Ipp32u)bitstreaminbps
Ipp32ubitPerSample;//(Ipp32u)0ifcompressed
Ipp64fduration;//(Ipp64f)durationofthestream
AudioStreamTypestream_type;//(AudioStreamType)generaltypeofstream
AudioStreamSubTypestream_subtype;//(AudioStreamSubType)minortypeofstream
Ipp32uchannel_mask;//(Ipp32u)channelmask
Ipp32ustreamPID;//(Ipp32u)uniqueID
       vm_char stream_description[MAX_PATH];        The description of the StreamPID, for exapmle"english AC3"
boolis_protected;//audioisencrypted Ipp32uheader;//(Ipp32u)cancarryaudioheader(4-bytes) }AudioStreamInfo; I think, this additional information can found in the pmt.
Best Regards
Detlef
Pavel_V_Intel
I can add the language code to AudioStreamInfo, but creation of description lines is an application-level task.
thx a lot,will bevery useful,
best regards
Detlef
Will this feature implemented (additional language code)in the next release?
Best regards
Detlef
Ying_H_Intel
Hi Detlef,
Thanks for the asking. No,the feature is not in the next release. May be in next after next. I recorded the request in IPP feature request database. You will get notify when it is avaiable in some version.
Ying H.
