Community support and discussions relating to developing high-performance vision, signal, security, and storage applications.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Feature request ippiConvert_16u8u_C1RSfs
BMart1
New Contributor II
Gennady_F_Intel
could you submit this feature request to the intel online service center
BMart1
New Contributor II
Thanks, done.
Igor_A_Intel
Hi Bruno,
you can use a workaround which is more flexible:
IPPAPI(IppStatus, ippiScaleC_16u8u_C1R , ( const Ipp16u* pSrc, int srcStep, Ipp64f mVal, Ipp64f aVal, Ipp8u*  pDst, int dstStep, IppiSize roiSize, IppHintAlgorithm hint ))
This function scales pixel values of the source image ROI and converts them to the destination data type according to the following formula:
dst = saturate_to_dstType(src * mVal + aVal)
regards, Igor
BMart1
New Contributor II
Hi Igor,
Thanks for the suggestion. ippiScaleC_16u8u_C1R does work. The results are not exactly the same because it uses floats, which probably also makes it slower. I ended up writing the functions with intrinsics.
Bruno
