FloodFill / distanceTransform
lital
I want to fill image holes, using a distance transform of another image.
Is there a way - to get aclosest pixels map(i.e. not only the distance map , but also the closest pixel'slocation/adress)or to flood fill an image using another image's non zero pixels and theirclosest pixels??
Thank you..
Vladimir_Dudnik
This functionality (distance transform with the labels of the nearest points) has been added to the very latest CVS version of OpenCV
that can be retrieved from SourceForge:
http://sourceforge.net/cvs/?group_id=22870
Actually, it is not exactly what it requested, because all pixels in a connected component have the same labels, so the labels of the nearest connected components, not the nearest pixels, are returned. Though, this feature can be easily added, if need.
Vladimir
