6825 Discussions
How to decode GSM-EFR ( GSM 6.60 ) with IntelIPP?
telefonie
I am searching for sample code to decode GSM-EFR (GSM6.60) with Intel-IPP.
regards,
telefonie
Message Edited by telefonie on 11-29-2005 02:51 AM
Ivan_Ryzhachkin__Int
GSM AMR provides GSM EFR mode
(frame type)7 - 12.2 kbit/s (GSM EFR)
Ivan
telefonie
Hello Ivan,
sure you are right, but I am a little bit to lazy to search for a solution of open problems if its already done. Do you have decoded already real GSM-EFR with the Intel-IPP GSMAMR-Decoder or is this only a theoretical answer?
Here the main differences:
a.) The SID frame is another type as for GSMAMR. May I pass the SID frames to the GSMAMR decoder? This may no great problem if i ignore the SID frames and throw them away.
b.) I think RTP-Payloadformat for GSM-EFR is another as GSMAMR (see e.g. rfc 3551 for GSM-EFR and rfc3267 for GSMAMR).
I like to test with real rtp-streams.
Unfortunally I have no testdata for GSM-EFR. Best case if I had a sip-client with GSM-EFR Codec to produce a rtp-stream, but I didnt know one. An Ethereal PCAP-File of a complette RTP-Communication (GSM-EFR) may also help testing the decoding.
Do someone knows how to produce real GSM-EFR data (best as a rtpstream e.g. SIP-Communication).
Joachim
Message Edited by telefonie on 11-30-2005 08:01 AM
Hi Joachim,
unfortunately we don't dispose with the "pure" GSM EFR codec at the moment.
))it's not a problem to substitute SID-frames using some"white" noise.
)) The SID-freeGSM EFR data can be produced with the GSM AMR encoder if VAD-mode is switched-off.
ATB
Ivan
telefonie
Hello Ivan,
may it work correctly if I throw away all SID-Frames? Ill fill the silence correctly (according to the RTP Timestamp) after decoding with lin16 with value 0. I ignore "Comfort Noise" till now.
I give the decoder only the normal 12.2Kbit frames. It shall works then, or?
How do you Interpret rfc 3551 for GSM-EFR and rfc3267 for GSMAMR.
How it is GSM-EFR transfered with RTP?
My Opinion:
RTP-Payload like GSM-FR(=GSM6.10) (see rfc 3551) but bits of frame sortet like (frame type)7 - 12.2 kbit/s from GSMAMR?
Which SDP-Parameter are possible for GSM-EFR?
Has someone GSM-EFR Data (RTP-Packets) out of a RTP-Communication, or know someone a client to produce a RTP-Stream? I have no client to produce the Data.
telefonie
Igor_B_Intel1
Hi!
Let me just clarify. You could decode GSM-EFR stream with GSM-AMR only if it contains active frames. CN module in GSM-AMR doesn't substitute CN module in GSM-EFR as it done for active frames. And they have god different length for SID frames. Try tointerpret SID frames from GSM-EFRas lost frames. I think it degrades quality but it can work.
Active frames packs in 248 bits: 4 bit for 0xC and 244 bits for bitstream without reordering.
In SDP message for GSM-EFR you can use any number from 96 till 127 because it hasn't got static payload type.
Igor S. Belyakov
Thomas_B_1
Hi
i want to packetize AMR in 12.2, so i mean EFR, i use 5.2_beta samples and its codec amr, i have a 31 bytes packet returned by the Encoder (320 bytes PCM) but i'm not able to packetized it correctly. I supposed this packet is the 244 bits bitstream so i try to add CMR and F FT Q at the beginning but it doesn't work...
ligoban
Dear Joachim,
I would like to communicate with you. I hope you've got my letter ( pseudor_lib@yahoo.com ).
Sorry for the offtopic.
