It should be right that to chang the starting point and region of interest each time while using "add or Copy" in ipp , to copy a small image to another big image.
For example,
big image
1 2 3 4 5
6 7 8 9 10
11 12 13 14 15
16 17 18 19 20
the (0, 0) point : pSrcDst
small image
1 2
3 4
the starting point: pSrc
roiSize = {2, 2};
You may change pSrcDst to pSrcDst to pSrcDst+2 to piont (0, 2) , use
IppStatus ippiAdd_
(please note : as the Regin of interest is unchanged in the case, you don't need change it)
to add
3 4
8 9
and
1 2
3 4
if move pSrcDst to pSrcDst+3, then add
4 5
9 10
and
1 2
3 4.
Ying
3 4
8 9
and
1 2
3 4
4 5
9 10
and
1 2
3 4
It looks like there is a small error in the description of the solution. It adds values {2,4} to {4,9} and then again {1,3} to {4,9}.
I underlined all these values.
Sergey
EDerman wrote:Dear all, I am going to add one small image data to another big one, but I need to repeat copying the small one to fill out all the big image region. This is similar to copying one small matrix data repeatedly to one bigger matrix in a loop in c++, etc. Is there any good way to do this? I was thinking about changing the starting point and region of interest each time while using "add" in ipp, which sounds also like a loop. But I failed. Many thanks in advance. Best regards, Ederman
