Thank you for your help.
In the median filter's "ippiFilterMedianBorder_8u_C1R" function
I am having trouble with a phenomenon where the speed becomes more than 10 times slower when updating the IPP version.
Prepare an 8-bit grayscale image of 1000 pixels horizontally and 1000 pixels vertically.
Run a median filter.
Briefly summarized below:
The environment is
CPU:14900K
MEM:64GB
OS:win11 (latest)
parameters
Image: 8bitGray 1000x1000
Mask size: X=201, Y=1
Border processing type: ippBorderInMem
*() shows the same image size with 24-bit color.
<IPP_ver2021.1.1> It's fast
Processing speed: 3.5ms (10.1ms)
Buffer size obtained with ippiFilterMedianBorderGetBufferSize:
503,904byte (900,000byte)
<IPP_ver2021.12> Slow speed
Processing speed: 40.0ms (11.3ms)
1,117,984byte (900,000byte)
In comparison, in the case of 8bitGray, the new IPP version takes more than 11 times the processing time.
I feel like something is wrong with the required buffer size, which is more than double.
What is interesting is that the new IPP version has a larger data size than 24bit color.
This means that 8bitGray, which is smaller in size, is slower in processing...
I would appreciate it if you could confirm whether this is a problem or not.
What happened to this question?
Thank you for posting in the forum.
I built a test and ran it on my side, but didn't see this performance drop.
<IPP_ver2021.4.0> (not tested with 2021.1.1 version though)
status of ippiFilterMedianBorderGetBufferSize: 0
Buffer size: 503904
status of ippiFilterMedianBorder_8u_C1R: 0
elapsed time: 4.41866 ms
Exit status 0 (ippStsNoErr: No errors)
<IPP_ver2021.12>
Buffer size: 1117984
elapsed time: 4.37008 ms
Did you do warm up runs? I can see the elapsed time getting one order of magnitude higher (~10 ms) for the first run.
Fengrui
Hi.
Thank you for your reply.
I didn't explain enough, but with the software currently being developed,
I am using <IPP_ver2021.1.1>.
Therefore, if you use <IPP_ver2021.2.0> or later than <IPP_ver2021.1.1>,
I'm having trouble updating my IPP because the speed has become so slow.
Therefore, I would like you to compare it with <IPP_ver2021.1.1>.
There is another thing that caught my attention from the answers I received.
When compared with <IPP_ver2021.4.0>, <IPP_ver2021.12> has a smaller buffer size.
That's about twice as much.
<IPP_ver2021.4.0> Buffer size: 503904
<IPP_ver2021.12> Buffer size: 1117984
How does this phenomenon occur?
I would appreciate it if you could answer the above questions.
Thank you for your support.
Thank you for posting the issue. For better investigating the issue, please share out your simple reproducer.
