(IJL) Encoding YUV UYVY to JPEG
jwmcfar
Hi all.
I have a YUV buffer in 4:2:2 subsampling in the UYVY format. I need to encode it to a JPEG in standard YUYV.
The IJL library that is on top of IPP does not seem to support UYVY. Is there any easy way to do the conversion and / or compress the image without needing to dig deep into the IPP API itself?
Josh McFarlane
Vladimir_Dudnik
Hi Josh,
you probably cam use ippiSwapChannels function to change channel order from UYVY to YUYV (aka YUY2)
Vladimir
