IPL::ComputeHisto for signed images
dario_ramos
Hi guys,
I'm trying to use IPL's (version 2.5) ComputeHisto function for a signed image. At first, I got a "key < 0" error. I solved it passing IPL_DEPTH_16S to iplCreateImageHeader (the image is 16 bits signed). But now I get this:
(srcImage->depth & IPL_DEPTH_SIGN) || (srcImage->depth == IPL_DEPTH_32F)
If I understood right, this means IPL can't compute a histogram for signed images... Is this really true? If it is, could anyone suggest an alternative?
dario_ramos
RTFM! In the IPL Reference, Appendix A, Table A-9, it says that ComputeHisto only supports 1u, 8u, and 16u. So I'll have to implement this myself...
renegr
Where's the problem? You can use also the unsigned histogram function and interpret the lower half as the positive values, the upper half as the negative ones (1->1; 2->2; ...; 32767->32767; 65535->-1; 65534->-2 ...)
