6847 Discussions
IPP 4.1.008 B-Frame Code Not Invoked with Encoder
jvrinc
I am using the code samples for IPP 4.1.008 (downloaded w_ipp-sample-video_pu_4.1.008). I have configured the .par file as follows:
H264 Sequence.
foreman.cif /* name of source files */
300 /* number of frames */
1 600 /* 1(reserved) , N (# of frames in between I frames) */
1 /* Number of B frames between I (or P) and next P */
352 /* horizontal_size */
288 /* vertical_size */
5 /* frame_rate_code */
0 10 26 26 300000 /* method(0 - quant_codes, 1 - CBR, quant_codes (I P B) & bitrate !!!ALL must be specified */
1 4 4 0 /* extra block split, search x,search_y, implicit weighted biprediction(reserved)*/
352 /* display_horizontal_size */
288 /* display_vertical_size */
0 sample.log /* log mask and template filename of log-file (0 and "any value" for none) (not implemented yet)*/
This results in 1x I-Frame as I expect, but no B-Frames. I've stepped thru the code and the B-Frame code is never invoked in the encoder. Any suggestions?
Ying_S_Intel
Dear Customer,
This has been fixed in the latest version IPP 5.0 beta. Please enroll this beta program and download the IPP media processing sample that includes H.264 decoder/encoder component.
The IPP 5.0 beta program is located at http://www.intel.com/software/products/ipp/beta
Ying
Intel Corp.
