I couldn't find any libs for PXA255 of the new IPP 5.0. Is it so that this processor will not be supported by the new libraries?
br, Kim Fredenberg
br, Kim Fredenberg
Please note thatIPP for IXP will work on PXA255 processor, so you can use these libraries.
Vladimir
I compiled a small mp3player against the IXP IPP 5.0 libraries (IXP). Now it seems that there is great performance degradation. While the IPP 4.1 library decoded the mp3 files using about 15% CPU, IPP 5.0 now uses 30%. I compiled both using the same GCC crosscompiler with the VFP patch applied.
Why this significant performance loss?
br, Kim Fredenberg
br, Kim Fredenberg
Hi Kim,
we fixed several bugs in IPP functions, it cause some performance degradation. Now we are workto improve performance of affected functions.
Vladimir
I'm porting an application which uses IPP library.
First, I 've adapted it for PXA270 processor on WINCE 5.0 and it's working.
Now, I'd like to port it for PXA255 on WINCE 4.2. So I'm using library w_ipp_ixp_p_5.0.023.exe. But there are some differeces in the interface. For example, there isn't ippiDCT8x8Inv_Video_16s_C1I function. It exits ippiDCT8x8Inv_16s_C1I.
Is it the equivalent function ???
Then, there 2 functions by category for example ippacs2l.lib and ippacsxl.lib. What is the difference and which one must I use ???
Many thanks in advance for your help
Maxime
Maxime
Hi Maxime,
yes, functions ippiDCT8x8Inv_Video_16s_C1I and ippiDCT8x8Inv_16s_C1I are equivalent.
Regarding library names, I whant to inform you that we use special postfixes in the library names to distinguish libraries which contains code optimized for that architecture in general (without using ASM code) - SX and highly optimized code, written in ASM where it makes sense - S2.
Vladimir
Hi Vladimir,
Thanks for your response.
I post a new message in the forum to ask which library I must use for PXA255 and ysong (moderator) said me that I must use IPP 4.1.2.
I see IPP 4.2 and the interface is compatible with IPP 5.0. So with this library, I needn't to modify my code.
So my question is :
Is it better to use IPP5.0 for IPX or to use IPP4.1 for PXA ???
And where could I find IPP4.1 because on the site, we can download only the latest version of IPP ???
Many thanks in advance for your help.
Maxime.
So my question is :
Maxime.
