6847 Discussions
IPP 5.1 Linux static linking unresolved reference
peter77
I'am working with IPP Version 5.1 under Windows and Linux and everthing works fine static/dynamic linking.
Now I used a function called
ippsGetCodebook_32f
and only under Linux with static linking I get a lot of errors like the following:
../../../packages/ipp/5.1/lnx_gcc/lib/libippsrmerged.a(pscdbk32.o)(.text+0x7d):
In function `px_ippsGetCodebook_32f':
: undefined reference to `px_ippsCopy_32f'
../../../packages/ipp/5.1/lnx_gcc/lib/libippsrmerged.a(pscdbk32.o)(.text+0x231):
In function `OwnCreate1stCluster_32f':
: undefined reference to `px_ippsMalloc_8u'
../../../packages/ipp/5.1/lnx_gcc/lib/libippsrmerged.a(pscdbk32.o)(.text+0x258):
With windows everthing works fine and with linux and dynamic linking also. Is there maybe a known problem that this function get lost while creating the static libs ?
Peter
Vladimir_Dudnik
This function (ippsGetCodebook_32f)call other IPP functionsinternally, for example ippsCopy_32f' and ippsMalloc_8u. Please check if you link ipps library which contains these functions and make sure that correct order of libraries is used in your linker call
Vladimir
