IPP 5.1 Usc_ec problem
malot
I tried usc_ec (Echo Cancellation) application with IPP 5.1for windows. I am able to build the code properly and it generates usc_ec.exe in the binia32 directory but when I run the app with appropriate parameters it says "Cannot find EC_FP (or EC_INT) echo canceller". Please help.
Ashish Malot
Vyacheslav_Baranniko
New Contributor II
Hi Ashish Malot
Unfortunately, there are a documentation and application bugs in the USC EC 5.1 sample.
First, in the readme.htm in the section "How to run..." should be read
"-type ]" instead of "-type ]", and so the same bug is in outputhelp message of the application.
Second,default value for option "-type" does not work.
So, pleaseuse option
-type ]
at least one has to be in command line.
For example. you may add to usc_ec command line option the following
-type IPP_EC_INT
Sorry for inconvonience.
Vyacheslav
