6685 Discussions
IPP 7.0 H264 decoder gives corrupted o/p when i/p with H264 High profile video
mehrotra_kk
i was trying to decode a H264 high profile encoded video stream (1920x1080) using IPP 7.0 single threaded H264 decoder. The decoded output comes out to be lot of green lines after some initial frames.
regards
abhishek mehrotra
Chao_Y_Intel
Hi abhishek,
Could you provide the test bit stream? so we can have a check.
Chao
mehrotra_kk
I have a added one example h264 encoded stream which shows corruption problem when decoded with ipp 7.0 h264 decoder.
abhishek
mehrotra_kk
please find the encoded h264 stream here
mehrotra_kk
Is anyone at the intel side able to reproduce this problem atleast ??
Chao_Y_Intel
I checked with IPP sample code for windows with the simple player, and could not reproduce the problem.
The video decoder looks to work fine. could you check that attached decoded YUV file? see if this is the correct data ( the decoded file are too large, only part of the video frame are attached).
Chao
