IPP 8.1 - ippsFIRGetStateSize_32f
Michal_B_Intel
I have a question about FIR filtering functionality. When I ask for the FIR state buffer size using method below:
ippsFIRGetStateSize_32f( int tapsLen, int *pBufferSize )
I get unusually huge values e. g. 17792 for tapsLen=1. Is this expected? From what I understood from documentation the FIR state structure contains taps values and delay buffer. I see no reason why this should be this big.
Chao_Y_Intel
Hi Michal,
What is the processor you find the problem?  Is it a 32 bit code, or Intel 64 bit code?
Chao
Michal_B_Intel
It's 64-bit.
Michal
Michal_B_Intel
Is there any chance for an update on this issue?
Michal
Igor_A_Intel
HI Michal,
I guess that for 1 tap FIR it's better to use ippsMulC_32f function :)
As the same state structure is used for in-place and out-of-place FIR processing functions, the main part of this state structure is temporal buffer for in-place function - 4K floats = 16K bytes.
regards, Igor
Michal_B_Intel
Hello.
The 1-tap filter was an example I plan to use longer ones but the memory usage grows too rapidly with each tap.
Thanks for clarifying this, I guess that I'll have to implement my own FIR.
Michal
Igor_A_Intel
Hi Michal,
did you receive my private message for you?
regards, Igor
