IPP-Headers and Delphi, again
monacor101
i try to convert a fully coded FFT transformation using the IPP Libraray from C++ to Delphi. Transfering the headers from C++ to Delphi, ok it is a question of application. But one IPP comand makes trouble: IppStatus ippsFFTInitAlloc_C_32f(IppsFFTSpec_C_32f** ppFFTSpec, int order, int
flag, IppHintAlgorithm hint); The definition of the IppsFFTSpec_C_32F type is not done in a public header, as described in the manual.
Any idea how to convert this hidden structure to something usefull in Delphi?
Thanx a lot!
CK
Vladimir_Dudnik
you mignt be interested with reading some similar topics here
Calling Intel's IPP from Delphi6
Intel IPP and headers
ROI for DFT (Delphi)
Vladimir
monacor101
There is no hint in the demo so i found out by myself:
The C-Types
ppsFFTSpec_C_32F
ppsFFTSpec_C_64F
are represented in Delphi as:
type IppsFFTSpec_C_32f = Pointer;
type PIppsFFTSpec_C_32f = ^IppsFFTSpec_C_32f;
type IppsFFTSpec_C_64f = Pointer;
type PIppsFFTSpec_C_64f = ^IppsFFTSpec_C_64f;
So the Alloc-Function is defined then:
ippsFFTInitAlloc_C_64f(pFFTSpec : PIppsFFTSpec_C_64f; ...
Hope anyone else can use it, too.
Vladimir_Dudnik
Thanks, I think it should be interesting for those who use IPP in Delphi environment
Vladimir
