IPP Max Image Size
albas
I'd like to know what is the maximum image size IPP can deal with.
I have a program using images allocated with ippiMalloc_8u_C3 and using this two functions :
ippiImageJaehne_8u_C3R
ippiThreshold_GT_8u_C3R
They work fine with1728*1152 images, but I need to work also with3504*2336 images, and this functions don't seem to work with this image size.
I can't find in the Doc's what is the max image size to work with IPP. Can you help?.
Thanks in advance.
Vladimir_Dudnik
what do you mean under seems does not work with such images? Does function return error code? If so, could you please specify what exactly happened?
These sizes are not so big, so IPP should work with such sizes.
Vladimir
