IPP RGB24 to YV12 or I420 with no ippmirror
yann_stephan
Please find enclosed an example of a code that will convert a RGB24 to YV12 or I420 without using the ippMirror function as final step.
In fact the filling will be done form the bottom line to top line, by having a negative destination step.
Hope it can help.
Yann
BOOL CHPColorConverter::Convert_RGB24(IMediaSample * pIn, IMediaSample *pOut, AM_MEDIA_TYPE * pmtIn, AM_MEDIA_TYPE * pmtOut)
LPBYTEpData;
LPBYTEpVideoBuffer;
Ipp8u*pYUV[3];
intdstStep[3];
longlDataLen;// Holds length of any given sample
longlInDataLen, lOutDataLen;
if ((pIn != NULL) && (pOut != NULL))
if ((pIn->GetPointer(&pData) == S_OK) && (pOut->GetPointer(&pVideoBuffer) == S_OK))
lDataLen= pIn->GetSize();
lInDataLen= pIn->GetActualDataLength();
lOutDataLen= pOut->GetActualDataLength();
long lComputedSize= ((m_nOutWidth * m_nOutHeight) + (((m_nOutWidth / 2) * (m_nOutHeight/2)) * 2));
if (lOutDataLen >= lComputedSize)
IppiSize roiSize = {m_nInWidth, m_nInHeight};
pYUV[0]= (Ipp8u *) pVideoBuffer + (m_nOutWidth * m_nOutHeight) - m_nOutWidth;
pYUV[1]= (Ipp8u *) (pYUV[0] + m_nOutWidth + ((m_nOutWidth * m_nOutHeight) / 4)) ;
pYUV[2]= (Ipp8u *) (pYUV[1] + ((m_nOutWidth * m_nOutHeight) / 4));
// TODO : Try negative value
dstStep[0] = -m_nOutWidth;
dstStep[1] = -(m_nOutWidth / 2);
dstStep[2] = -(m_nOutWidth / 2);
if (pmtOut->subtype == MEDIASUBTYPE_YV12)
ippiRGBToYCbCr420_8u_C3P3R((const Ipp8u*) pData, m_nInWidth*3, pYUV, dstStep, roiSize);
else
ippiRGBToYUV420_8u_C3P3R((const Ipp8u*) pData, m_nInWidth*3, pYUV, dstStep, roiSize);
pOut->SetActualDataLength(lComputedSize);
return TRUE;
return FALSE;
Vladimir_Dudnik
Thank you Yann,good and useful tip.
Note, historically, not all IPP functions do support negative step, but we extending that list. If negative step is not supported functions will return error code (not access violation!).
Vladimir
