IPP cryptography performance problem
szhen22
hello:
      I'm using IPP cryptography API  to develop program! do you have any documents about   optimization cryptography API  performace comparing with not  optimization cryptography  algorithem?
     Because ,when I was testing the RSA algorithem , I find the intel IPP RSA  algorithem performance wasn't well with openssl sorce code! If you have any testing report or document abot  cryptography algorithem optimization compare with not optimization ,can you send to me ? thank you!
Zhen_Z_Intel
Hi sunny,
Could you provide more information including OpenSSL version, IPP crypto version, RSA key size? which CPU you are using (SIMD)? How the performance you tested like?
If you have more question, please submit your request through Intel Online Service Center, and paste your information there. Thanks.
Fiona
szhen22
hello Fiona:
       the openssl  version is :1.0.01;
       the intel ipp cp name and version is :Name:ippCP AVX2 (l9),Version: 2017.0.3 (r55431) _2017.0.3.55431
       the intel CPU is :E3-1225
       the following is testing  performance data between openssl and intel ipp cp lib:
Generate key pair:
Key length
(bits)
Openssl
( pairs/s)
Intel ipp
(pairs/s)
1024
59
35
2048
10
5
RSA encryption and decryption:
function
Key length
(bit)
Data
(bytes)
Openssl
(times/s)
Intel ipp
(times/s)
ippsRSA_Encrypt
1024
128
104341
87368
2048
256
31945
27745
ippsRSA_Decrypt
1024
128
5907
7547
2048
256
958
1500
RSA sign and verify:
function
Key length
(bit)
Data
(bytes)
Openssl
(times/s)
Intel ipp
(times/s)
ippsRSASign_PSS
1024
128
5915
7085
2048
256
971
1345
ippsRSAVerify_PSS
1024
128
105508
89106
2048
256
31998
27855
   from the datasheet, we can find intel RSA key pair generate isn't well with openssl, otherwise ippsRSA_Encrypt and ippsRSAVerify_PSS alse aren't  well withe opensll!
szhen22
the performance tesing data is attached files, it is word document,please open this !
Zhen_Z_Intel
Hi Sunny,
I've post your testing report to our developing team to have a check and will give you a reply soon. Thanks.
Fiona
szhen22
hello:
    I haven't received any respond from your development team about this question for such many days. Can you tell me when they will answer me about my question? I'm waiting for your respond to reslove my development program. Sincerely, hope will be so fast ,thank you very much!
   Otherwise ,can you send me about your testing performance report about RSA algorithem by your development team? thanks!
