IPP to use GPU
rohitspandey
HI,
Does the IPP libaries can be enabled to use openCL to utilise GPU.
Rohit
Jeffrey_M_Intel1
Hi Rohit, Today IPP is CPU only. However, this is a topic that the IPP team is very interested in. If/when there are any updates on GPU utilization we'll broadcast here and elsewhere as soon as possible. Thanks, Jeff
SergeyKostrov
Valued Contributor II
Hi everybody, >>...Does the IPP libaries can be enabled to use openCL to utilise GPU... I think this is a very interesting subject and I wonder if you had a chance to review what was done by NVIDIA: NVIDIA Performance Primitives - https://developer.nvidia.com/npp
Bernard
Sergey Kostrov wrote:
Hi everybody,
One step closer from creation of powerful CPU-GPU "monster".
Bernard
Still CPU has some advantage mainly in areas of memory , cache management,out of order execution , speculative execution and exploiting instruction level parallelism. I think that in the foreseeable more advanced GPU's will some kind of "auxilliary" CPU used residing on board and which will be used instead of standard CPU.
rohitspandey
Hi, Thanks for the update!!. Definitely like to see its being used by IPP and MKL libraries. Our applications can heavley leverge from it. Regards Rohit
Eric_B_1
I would also like to point out that IPP is according to this going to be compatible with the Intel PHI. Close to the same context as GPU's Reference: IPP Coprosessor GPU's are still better on the price point but on the high end not by much. Also the IPP eq for CUDA is NPP -> just google cuda npp it comes with the SDK just FYI
Jeffrey_M_Intel1
Unfortunately Xeon Phi isn't officially supported by IPP. I'll see what I can do to update the article.
Eric_B_1
Bummer! Is it planned to be?
Jeffrey_M_Intel1
At this point there are no official commitments, so we don't want anyone to make plans on it being there. However, knowing about your interest is always helpful for product planning.
SergeyKostrov
>>At this point there are no official commitments, so we don't want anyone to make plans on it being there. However, knowing about your >>interest is always helpful for product planning. There are ideas around on adaptive hybrid high-performance algorithms and APIs. A main point is they should use CPU and GPU ( not at the same time! ) dependending on a state of processing, or algorithm, or function etc.
SergeyKostrov
Bernard
>>>There are ideas around on adaptive hybrid high-performance algorithms and APIs. A main point is they should use CPU and GPU ( not at the same time! ) dependending on a state of processing, or algorithm, or function etc.>>> Has not been this already implemented.IIRC some russian company was one of the first to use hybrid approach for cracking WPA2 cipher suite.
SergeyKostrov
>>...Has not been this already implemented... I wouldn't say so because we simply don't know what is going on inside of thousands of software companies. Application of adaptive hybrid high-performance algorithms which use CPU and GPU is a logical step in evolution of different kinds of algorithms. Also, I prefer to keep silence on what algorithm(s) I would apply that concept first of all.
Bernard
Yes I tend to agree with you, because by siimple logical reasoning it is impossible to know exactly what kind of research is beign done on hybrid CPU-GPU algorithms. I found this great website dedicated partly to CPU-GPU algorithms and to gpgpu programming :http://hgpu.org/?p=6140
Bernard
I also plan to invest my time and effort in learning CUDA programming.I think that today and even more in the foreseeable future it will be one of more needed looked for skills.
rohitspandey
Any time lines for supporting openCL or any other implmenetation to use GPU by IPP function.
SergeyKostrov
>>...gpgpu programming: http://hgpu.org/?p=6140
Abstract is interesting however it is an example of a highly specialized algorithm. I was talking about general purpose algorithms, that is more widely used by software developers.
Bernard
You can browse that website and try to look for more general purpose algorithmic implementation.Do not pay attention to abstract.
