6846 Discussions
Incorrect aspect ratio using MPEG-2 Decoder in the UMC samples
Pascal_Binggeli
Hello
I'm using IPP sample version 6.1.4.059.
I've found that the sample for the MPEG-2 decoder does not follow the ISO/IEC 13818-2 specifications for determining the sample aspect ratio. According to the 6.3.3 of the specifications, the aspect ratiomust bedeterminedfrom the sequence_display_extension()when this extension is present.
The implementation in MPEG2VideoDecoderBase::sequence_display_extension() simply ignore the display_horizontal_width and display_vertical_width, in umc_mpeg2_dec_pic.cpp, line 506:
GET_BITS_LONG(video->bs, 29, code)
should be replaced with
GET_BITS_LONG(video->bs, 14, display_horizontal_width)
SKIP_1BIT(video->bs)
GET_BITS_LONG(video->bs, 14, display_horizontal_height)
A consequence of this problem is that some clips are displayed using the wrong aspect ratio.
1. What is the correct way to report this issue for correction in future release ?
2. I'm wondering if this issue also affect the Intel Media SDK ?
3. Do I need to post in the Media SDK forum too ?
Cheers,
Pascal
Chao_Y_Intel
Hi Pascal,
Thanks for posting here. We will track this problem, and fix it in the future release.
I think you can also post it in the MediaSDK forum if it also need to be fixed in that pacakge.
Chao
Chao_Y_Intel
This fix has already been included in the 7.0 package.
Chao
