Insertion of SCTE 35 messages in MPEG-2 TS
Daniel_E-B
Hi.
I have to implement insertion of SCTE 35 splice informations into MPEG2 TS. Does UMC::MPEG2Muxer support this kind of operations?
What kind of objects should I use to be able to do this?
Should I be able to implement my own support for insertion of SCTE 35 messages into MPEG2 TS?
Chao_Y_Intel
Hi, some comments from our expert: The muxer/splitter only support on the media (audio/video) data only. User needs to develop their code if they want to support the private data. Thanks, Chao
Daniel_E-B
Hi, Thank's for the answer. Does this mean that I should create a sort of private stream data and modify the muxer for it to understand my private stream? What kind of UMC::MPEG2Muxer track type should I use to do so? Or should I insert the SCTE 35 splice information in the MPEG-2 TS after muxing? Thanks, Daniel
