Intel® IPP vs AES-NI
medeiros__jose
I have been working with a program that makes use of the AES-NI instructions, specifically AESENC  and AESKEYGENASSIST, and runs on the Intel Xeon Phi x200. In an attempt to improve its performance, I have been looking into using the IIPP, but from everything I have read the IIPP uses the same AES-NI functions. I have the following questions:
1. Does it make sense to look at IIPP as an alternative to AES-NI for the purpose of improving performance?
2. If it does, then what would be comparable to AESENC and AESKEYGENASSIST ?
Thank you,
Joe
Chao_Y_Intel
HI Joe,
AESENC and AESKEYGENASSIST are the CPU instructions.  IPP uses there instruction for AES encryption/decryption.
Chao
medeiros__jose
Thank you Chao, that's what I thought, but I wasn't sure. Given that, then the answer to the question: 1. Does it make sense to look at IIPP as an alternative to AES-NI for the purpose of improving performance? is no, correct?
Regardless, what would be the equivalent of _mm_aeskeygenassist_si128 and _mm_aesenc_si128?
Thank you very much,
Joe
Igor_A_Intel
Hi Joe,
IPP doesn't provide intrinsic analogues (that are just single cpu instructions) - IPP provides the full AES functionalities - please take a look at the IPP CP manual and ippcp.h header file:
/* AES */
IPPAPI(IppStatus, ippsAESGetSize,(int *pSize))
IPPAPI(IppStatus, ippsAESInit,(const Ipp8u* pKey, int keyLen, IppsAESSpec* pCtx, int ctxSize))
IPPAPI(IppStatus, ippsAESSetKey,(const Ipp8u* pKey, int keyLen, IppsAESSpec* pCtx))
IPPAPI(IppStatus, ippsAESPack,(const IppsAESSpec* pCtx, Ipp8u* pBuffer, int buffSize))
IPPAPI(IppStatus, ippsAESUnpack,(const Ipp8u* pBuffer, IppsAESSpec* pCtx, int ctxSize))
IPPAPI(IppStatus, ippsAESEncryptECB,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const IppsAESSpec* pCtx))
IPPAPI(IppStatus, ippsAESDecryptECB,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
IPPAPI(IppStatus, ippsAESEncryptCBC,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptCBC_CS1,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptCBC_CS2,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptCBC_CS3,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptCBC,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptCBC_CS1,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptCBC_CS2,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptCBC_CS3,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptCFB,(const Ipp8u* pSrc, Ipp8u* pDst, int len, int cfbBlkSize,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptCFB,(const Ipp8u* pSrc, Ipp8u* pDst, int len, int cfbBlkSize,
                                     const Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptOFB,(const Ipp8u* pSrc, Ipp8u* pDst, int len, int ofbBlkSize,
                                     Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESDecryptOFB,(const Ipp8u* pSrc, Ipp8u* pDst, int len, int ofbBlkSize,
                                     Ipp8u* pIV))
IPPAPI(IppStatus, ippsAESEncryptCTR,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                     Ipp8u* pCtrValue, int ctrNumBitSize))
IPPAPI(IppStatus, ippsAESDecryptCTR,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
IPPAPI(IppStatus, ippsAESEncryptXTS_Direct,(const Ipp8u* pSrc, Ipp8u* pDst, int encBitsize, int aesBlkNo,
                                     const Ipp8u* pTweakPT,
                                     const Ipp8u* pKey, int keyBitsize,
                                     int dataUnitBitsize))
IPPAPI(IppStatus, ippsAESDecryptXTS_Direct,(const Ipp8u* pSrc, Ipp8u* pDst, int encBitsize, int aesBlkNo,
// AES based  authentication & confidence Primitives
/* AES-CCM */
IPPAPI(IppStatus, ippsAES_CCMGetSize,(int* pSize))
IPPAPI(IppStatus, ippsAES_CCMInit,(const Ipp8u* pKey, int keyLen, IppsAES_CCMState* pCtx, int ctxSize))
IPPAPI(IppStatus, ippsAES_CCMMessageLen,(Ipp64u msgLen, IppsAES_CCMState* pCtx))
IPPAPI(IppStatus, ippsAES_CCMTagLen,(int tagLen, IppsAES_CCMState* pCtx))
IPPAPI(IppStatus, ippsAES_CCMStart,(const Ipp8u* pIV, int ivLen, const Ipp8u* pAD, int adLen, IppsAES_CCMState* pCtx))
IPPAPI(IppStatus, ippsAES_CCMEncrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len, IppsAES_CCMState* pCtx))
IPPAPI(IppStatus, ippsAES_CCMDecrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len, IppsAES_CCMState* pCtx))
IPPAPI(IppStatus, ippsAES_CCMGetTag,(Ipp8u* pTag, int tagLen, const IppsAES_CCMState* pCtx))
/* AES-GCM */
IPPAPI(IppStatus, ippsAES_GCMGetSize,(int * pSize))
IPPAPI(IppStatus, ippsAES_GCMInit,(const Ipp8u* pKey, int keyLen, IppsAES_GCMState* pState, int ctxSize))
IPPAPI(IppStatus, ippsAES_GCMReset,(IppsAES_GCMState* pState))
IPPAPI(IppStatus, ippsAES_GCMProcessIV,(const Ipp8u* pIV, int ivLen,
IPPAPI(IppStatus, ippsAES_GCMProcessAAD,(const Ipp8u* pAAD, int ivAAD,
IPPAPI(IppStatus, ippsAES_GCMStart,(const Ipp8u* pIV, int ivLen,
                                    const Ipp8u* pAAD, int aadLen,
IPPAPI(IppStatus, ippsAES_GCMEncrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len, IppsAES_GCMState* pState))
IPPAPI(IppStatus, ippsAES_GCMDecrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len, IppsAES_GCMState* pState))
IPPAPI(IppStatus, ippsAES_GCMGetTag,(Ipp8u* pDstTag, int tagLen, const IppsAES_GCMState* pState))
/* AES-XTS */
IPPAPI(IppStatus, ippsAES_XTSGetSize,(int * pSize))
IPPAPI(IppStatus, ippsAES_XTSInit,(const Ipp8u* pKey, int keyLen,
                                   int duBitsize,
                                   IppsAES_XTSSpec* pCtx,int ctxSize))
IPPAPI(IppStatus, ippsAES_XTSEncrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int bitSizeLen,
                                      const IppsAES_XTSSpec* pCtx,
                                      const Ipp8u* pTweak,
                                      int startCipherBlkNo))
IPPAPI(IppStatus, ippsAES_XTSDecrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int bitSizeLen,
/* AES-SIV (RFC 5297) */
IPPAPI(IppStatus, ippsAES_S2V_CMAC,(const Ipp8u* pKey, int keyLen,
                                    const Ipp8u* pAD[], const int pADlen[], int numAD,
                                          Ipp8u* pV))
IPPAPI(IppStatus, ippsAES_SIVEncrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                            Ipp8u* pSIV,
                                      const Ipp8u* pAuthKey, const Ipp8u* pConfKey, int keyLen,
                                      const Ipp8u* pAD[], const int pADlen[], int numAD))
IPPAPI(IppStatus, ippsAES_SIVDecrypt,(const Ipp8u* pSrc, Ipp8u* pDst, int len,
                                      int* pAuthPassed,
                                      const Ipp8u* pSIV))
/* AES-CMAC */
IPPAPI(IppStatus, ippsAES_CMACGetSize,(int* pSize))
IPPAPI(IppStatus, ippsAES_CMACInit,(const Ipp8u* pKey, int keyLen, IppsAES_CMACState* pState, int ctxSize))
IPPAPI(IppStatus, ippsAES_CMACUpdate,(const Ipp8u* pSrc, int len, IppsAES_CMACState* pState))
IPPAPI(IppStatus, ippsAES_CMACFinal,(Ipp8u* pMD, int mdLen, IppsAES_CMACState* pState))
IPPAPI(IppStatus, ippsAES_CMACGetTag,(Ipp8u* pMD, int mdLen, const IppsAES_CMACState* pState))
regards, Igor
medeiros__jose
Thank you Igor for clarifying this.  Obviously this is not my area and thanks for your help.
