Mac OSX 64-bit IPP Libraries?
Kevin_Wilson
In Linux I link to seperate folders for my 32-bit vs. 64-bit compiles:
/opt/intel/Compiler/11.1/069/ipp/ia32
/opt/intel/Compiler/11.1/069/ipp/em64t
In Mac there is no seperate folder under /opt/intel/Compiler/11.1/084/ipp/ . How do I check if I have the 64-bit IPP libraries installed?
Note: I have successfully compiled my code in 32 and 64-bit versions on Mac linking to the same folder, and although the 32-bit works as intended, the 64-bit crashes. This could be a lot of things, but I was wondering if I should be linking to different libraries.
Thanks for any help,
Kevin
Ying_H_Intel
Hi Kevin,
IPP combines both ia32 and inter64 inexisting staticlibrary. (knows as universal library). So you don't need to set different folder and library for the 32bit or 64bit IPPapplicationunder Mac.
Kind Regards,
Ying
Kevin_Wilson
I am still unclear of why there is not seperate libraries for IPP under Mac.
/opt/intel/Compiler/11.1/084/Frameworks/ipp/lib/ ??
Should there be a ia32 and intel64 folder?
Kevin
Ying_H_Intel
Hi Kevin,
Kind Regards,
Ying
Juan_Yanez
Where are the following libraries in the latest OSX compiler? I have code that used to compile and work just fine, but after upgrading to the C++ composer XE 2011 for OSX my code does not link anymore.
ippcorel.lib
ippiemerged.lib
ippimerged.lib
ippsemerged.lib
ippsmerged.lib
ippccmerged.lib
ippccemerged.lib
Vladimir_Dudnik
in IPP 7.0 we have changed product folder structure and library naming convention to simplify linkage and to provide more consistent look and feel across different architectures. Please check New Directory Structure and Library Naming Scheme for Intel IPP 7.0 Library IPP Knowledge Base articel for more details.
Vladimir
Juan_Yanez
Thanks for the info. Ok, I am past the compile time errors. Now I have link time errors:
"_ippJumpIndexForMergedLibs", referenced from:
_ippJumpIndexForMergedLibs$non_lazy_ptr in libippcc_l.a(ippcc00415as.o)
_ippJumpIndexForMergedLibs$non_lazy_ptr in libippcc_l.a(ippcc00421as.o)
_ippJumpIndexForMergedLibs$non_lazy_ptr in libippcc_l.a(ippcc00419as.o)
_ippJumpIndexForMergedLibs$non_lazy_ptr in libippcc_l.a(ippcc00413as.o)
(maybe you meant: _ippJumpIndexForMergedLibs$non_lazy_ptr)
"_ipp_set_cw_ssx", referenced from:
_v8_ippiColorTwist32f_8u_C3R in libippcc_l.a(pcctwistca_split_v8_ippiColorTwist32f_8u_C3R.o)
_w7_ippiColorTwist32f_8u_C3R in libippcc_l.a(pcctwistca_split_w7_ippiColorTwist32f_8u_C3R.o)
_v8_ippiColorTwist32f_8u_AC4R in libippcc_l.a(pcctwistca_split_v8_ippiColorTwist32f_8u_AC4R.o)
_w7_ippiColorTwist32f_8u_AC4R in libippcc_l.a(pcctwistca_split_w7_ippiColorTwist32f_8u_AC4R.o)
_v8_ippiColorTwist32f_16u_C3R in libippcc_l.a(pcctwistca_split_v8_ippiColorTwist32f_16u_C3R.o)
_w7_ippiColorTwist32f_16u_C3R in libippcc_l.a(pcctwistca_split_w7_ippiColorTwist32f_16u_C3R.o)
_p8_ippiColorTwist32f_8u_AC4R in libippcc_l.a(pcctwistca_split_p8_ippiColorTwist32f_8u_AC4R.o)
_w7_ippiColorTwist32f_16u_AC4R in libippcc_l.a(pcctwistca_split_w7_ippiColorTwist32f_16u_AC4R.o)
_v8_ippiColorTwist32f_16u_AC4R in libippcc_l.a(pcctwistca_split_v8_ippiColorTwist32f_16u_AC4R.o)
_p8_ippiColorTwist32f_16u_AC4R in libippcc_l.a(pcctwistca_split_p8_ippiColorTwist32f_16u_AC4R.o)
_p8_ippiColorTwist32f_16u_C3R in libippcc_l.a(pcctwistca_split_p8_ippiColorTwist32f_16u_C3R.o)
_p8_ippiColorTwist32f_8u_C3R in libippcc_l.a(pcctwistca_split_p8_ippiColorTwist32f_8u_C3R.o)
"_ipp_set_rc_ssx", referenced from:
ld: symbol(s) not found
In the "other linker flags" I've got
-lippi -lippcore -liomp5
and I've linked in
libippicore.a
lipippi_l.a
lipipps_l.a
lipippac_l.a
lipippcc_l.a
lipippi_cv.a
lipippj_l.a
jly
Vladimir_Dudnik
Do you mean you link with IPP libraries twice, the first time in your "other linker flags", where you specified to link with ippi and ippcore shared libraries and the second time when you explicitly linked with IPP static libraries (libippicore.a lipippi_l.a lipipps_l.a lipippac_l.a lipippcc_l.a lipippi_cv.a lipippj_l.a)?
That may not work this way. You need to decide how you would like to link, statically or dynamically.
Vladimir
Juan_Yanez
Problem fixed. I just needed to link againstlibippicore_l rather thanlibippicore
Juan_Yanez
Ok, let me ask you this then. What would I need to put in the "other linker flags"if I need to use the functions provided in the mentioned static libraries?
Vladimir_Dudnik
I do not know what "other linker flags" stands for. Usually, in order to link application, you need to specify the path where linker should look for the libraries and also specify library names to link.
Vladimir
Juan_Yanez
"other linker flags is a setting in the OSX XCode environment. They are link time flags pretty much. Is there a document that outlines what options need to be passed in to the linker for IPP 7.0 to work correctly on OSX? Up until now, I've been following the instructions described in Intel's book "Optimizing Applications for Multi-Core Processors". That book is based on version 5.2 of the IPP.
Vladimir_Dudnik
Wondering why you did not use product documentation for this purpose? For example, in IPP User's Guide you may review the article (also availble online by the link below)
Linking Your Application with Intel IPP
Also I would recommend you to review some IPP Knowledge Base articles regarding this topic
Intel IPP - Intel IPP linkage models - quick reference guide
Simplified Link Instructions for the IPP Library
Intel IPP for Mac OS* - How to link to the Intel IPP for Mac OS* X libraries in application?
Vladimir
