Multi-threading on IPP's H.264
eric_setton
I am using Intel IPP version 5.1 on a HP xw8400 Workstation. It has 2 x Dual-Core Xeon 5060 processors.
I am benchmarking the IPP H.264 encoder on my machine, but it seems multi-threading is not working as it should be. I never get more than a 25% use of my CPU. As I have 4 CPUs, this seems to indicate the program is running as if it were single-threaded.
Here are the different things I tried so far to get it to work, but all were unsucessful:
- increased the number of slices in the input parameter file
- turned option -r on
- tried option -t 4 (actually tried all -t 1 to -t 12, no change in performance).
I also checked the memory is not the limiting factor by using various resolutions for my YUV sequences.
Any tips or advice on how to improve this ? The performance isquitegood with 1 processor, and I would love to see it quadruple by usingefficiently the 4 cores.
Eric
Vladimir_Dudnik
Eric,
In IPP 5.1 media sample build script did not utilize OpenMP by default (so you need to add /openmp compiler option to h264_enc Makefile).
You may take IPP 5.2 beta media sample (it will require IPP 5.2 beta libraries) where threading is supported by default when you use Intel C/C++ compiler or MS VC 2005
Vladimir
