6847 Discussions
Multiple IPP H264 encoder class object in single application
jameslys
Can I create 2 H264 encoder class object in a single application by using 2 threads to handle the 2 encoders?
If can, how to do that?
I am using the umc examples that downloaded from intel ipp website.
shyaki
These two encoder instances are independent from each other.
If you use 2 threads to assess one encoder instance, you may need to synchronize your operations.
