Need Some help with the mp3encoder
john_s_17
hello
i am a newbie to the ipp.   i want to use the IPP to encoder PCM to MP3.
Now we use the lame (lame.sourceforge.net) to do this thing, encoder PCM to MP3.
we want to use the IPP 8.0  to instead of lame.
PCM  DATA is   8000hz      2channels
so i am tring like this.
    audio_encoder_params = new MP3EncoderParams();
    audio_encoder_params->m_info.audioInfo.m_iChannelMask =  CHANNEL_FRONT_LEFT | CHANNEL_FRONT_RIGHT;
    audio_encoder_params->m_info.audioInfo.m_iSampleFrequency = samplerate;
    audio_encoder_params->m_info.audioInfo.m_iChannels = channels;
    audio_encoder_params->m_info.iBitrate = 128000;
    audio_encoder_params->stereo_mode = UMC_MPA_LR_STEREO;
    audio_encoder_params->ns_mode = 0;
    audio_encoder_params->layer = 3;
    audio_encoder_params->force_mpeg1 = 0;
    audio_encoder_params->mc_matrix_procedure = 0;
    audio_encoder_params->mc_lfe_filter_off = 0;
    audio_encoder_params->mode = UMC_MPAENC_CBR;
    audio_encoder_params->m_pData = NULL;
    pAudioEncoder = new MP3Encoder();
    if (pAudioEncoder == NULL) {
        switch_log_printf(SWITCH_CHANNEL_LOG, SWITCH_LOG_ERROR, "Can't create audio codec object MP3!\n");
        return SWITCH_STATUS_FALSE;
    sts = pAudioEncoder->Init(audio_encoder_params);
    if (sts != UMC_OK) {
        switch_log_printf(SWITCH_CHANNEL_LOG, SWITCH_LOG_ERROR, "audioCodec Init failed: %d\n", sts);
    sts = pAudioEncoder->GetInfo(audio_encoder_params);
    if (sts < 0) {
        switch_log_printf(SWITCH_CHANNEL_LOG, SWITCH_LOG_ERROR, "audioCodec GetInfo failed\n");
    pOut = new MediaData();
    if (NULL == pOut) {
        switch_log_printf(SWITCH_CHANNEL_LOG, SWITCH_LOG_ERROR, "Memory allocation error\n");
    pOut->Alloc(context->mp3buflen);
    pIn = new MediaData();
    if (NULL == pOut) {
    pIn->Alloc(nsamples);
    memcpy((void *)pIn->GetBufferPointer(), (void *)audio, nsamples);
    pIn->SetDataSize(nsamples);
    log_printf(CHANNEL_LOG, LOG_DEBUG, "Input Data, Size: %d \n", pIn->GetDataSize());
    sts = pAudioEncoder->GetFrame(pIn, pOut);
    if (sts == UMC_OK) {
        log_printf(CHANNEL_LOG, LOG_DEBUG, "GetFrame OK, Size: %d \n", pOut->GetDataSize());
    } else {
        log_printf(CHANNEL_LOG, LOG_ERROR, "GetFrame Error: %d\n", sts);
    rlen = pOut->GetDataSize();
    if (rlen) {
        int ret = fwrite(pOut->GetBufferPointer(), 1, rlen, fp);
        if (ret < 0) {
            return STATUS_FALSE;
the question is
the data i input size is 16384
the pOut->GetDataSize()  just is 321.
when i use cool edit to view the mp3 file.   it just silence.
pls help me.  thank you very much.
Sergey_K_Intel
Hi John,
Looks like the rest of output data stalled in the encoder. Try to do one more GetFrame (or several  GetFrame calls) with datasize in pIn set to zero until pOut.GetDataSize() shows 0.
Sergey
john_s_17
To Sergey , Thank you very much.  i will do a test, then give you the result.
john_s_17
@Sergey , i have got a try tonight. Things become not so bad.
 .the file i save is almost noise. but a bit of the file is normal voice.  i add the wave by cooledit on attach.
by the way, whne i use the cooledit, i must chose the file type.
i think that  i use the wrong param.
More suggestions ?
john_s_17
@sergey, i have sovled the prolble.   GetFrame and fwrite the pOut to file.
god bless intel.
