I will be grateful if someone can tell if there are any functions to perform Integer maths using IPP.
Basically, I want to multiply a 3x3 matrix with 3x1 vector. Currently all the code is scalar and hence the performance sucks!, I hope to improve the performance using SIMD features of the processor, however can't find function which does maths on INTEGERS (16-bit).
I found an intrinsic which does only floating point 32 or 64-bit arithematic and not INTEGER.
If there is no such library, are there libraries for vector-vector DOT product or vector addition (adding all elements) in SIMD data-type.
Many thanks
Newbie
I would recommend you to start from looking at IPP documenation. Especially if you are newbie with IPP
You can try the following function
DotProd:
IPPAPI(IppStatus, ippsDotProd_16s_Sfs, (const Ipp16s* pSrc1,
const Ipp16s* pSrc2, int len, Ipp16s* pDp, int scaleFactor))
IPPAPI(IppStatus, ippsDotProd_16sc_Sfs,(const Ipp16sc* pSrc1,
const Ipp16sc* pSrc2, int len, Ipp16sc* pDp, int scaleFactor))
IPPAPI(IppStatus, ippsDotProd_16s16sc_Sfs, (const Ipp16s* pSrc1,
IPPAPI(IppStatus, ippsDotProd_16s64s, (const Ipp16s* pSrc1,
const Ipp16s* pSrc2, int len, Ipp64s* pDp))
IPPAPI(IppStatus, ippsDotProd_16sc64sc, (const Ipp16sc* pSrc1,
const Ipp16sc* pSrc2, int len, Ipp64sc* pDp))
IPPAPI(IppStatus, ippsDotProd_16s16sc64sc,(const Ipp16s* pSrc1,
IPPAPI(IppStatus, ippsDotProd_16s32f, (const Ipp16s* pSrc1,
const Ipp16s* pSrc2, int len, Ipp32f* pDp))
IPPAPI(IppStatus, ippsDotProd_16sc32fc, (const Ipp16sc* pSrc1,
const Ipp16sc* pSrc2, int len, Ipp32fc* pDp))
IPPAPI(IppStatus, ippsDotProd_16s16sc32fc,(const Ipp16s* pSrc1,
Math:
IPPAPI(IppStatus, ippsAdd_16s_ISfs, (const Ipp16s* pSrc, Ipp16s* pSrcDst,
int len, int scaleFactor))
IPPAPI(IppStatus, ippsAdd_16sc_ISfs, (const Ipp16sc* pSrc, Ipp16sc* pSrcDst,
IPPAPI(IppStatus, ippsSub_16s_ISfs, (const Ipp16s* pSrc, Ipp16s* pSrcDst,
IPPAPI(IppStatus, ippsSub_16sc_ISfs, (const Ipp16sc* pSrc, Ipp16sc* pSrcDst,
IPPAPI(IppStatus, ippsMul_16s_ISfs, (const Ipp16s* pSrc, Ipp16s* pSrcDst,
IPPAPI(IppStatus, ippsMul_16sc_ISfs, (const Ipp16sc* pSrc, Ipp16sc* pSrcDst,
Vladimir
Thanks Vladimir.
I was wondering if there are any primitives for
1) Matrix-Vector multiplication for integers
2) Multiply even and odd(seperately) 16-bit integer of 128 bit word i.e.
C[0] = A[0]*B[0]
C[1] = A[2]*B[2]
C[3] = A[6]*B[6]
And
D[0] = A[1]*B[1]
D[1] = A[3]*B[3]
D[3] = A[7]*B[7]
i.e some modification of "ippsMul_16s32s_Sfs()"
Newbie
I am performing a basic operation where I multiply a 3x3 matrix with 3x1 vector, and get another 3x1 vector.
All my inputs are 16-bit integers. The coefficients in the matrix remains constants, however the input vector change. Input 3x1 vector is 1000-elements long. So it can be assumed that I multiply the 3x3 with 3x1 input vector, fill the 3x1 input vector again and then multiply and then keep on doing so 1000 times.
I wrote both a scalar and a vector (SIMD) version of the code. To my surprise, thescalar version's performance is stillbetter than vector (SIMD) version using the IPP libraries.
Any suggestions pointer would be greatly useful.
Vimal
