OpenCV can't detect IPP 5.3 ...
jiapei1001
1) I'm pretty sure the problem is not as decribed here
http://support.intel.com/support/performancetools/libraries/ipp/linux/ia/sb/CS-028706.htm
2) I strictly follow the installation doc here
http://opencvlibrary.cvs.sourceforge.net/viewvc/*checkout*/opencvlibrary/opencv/INSTALL?revision=1.9
But,there is no such /bin subdirectory at all after I installed IPP - l_ipp_ia32_p_5.3.3.075
   + add /bin and /bin/linux32
(for example, /opt/intel/ipp/5.1/ia32/bin and /opt/intel/ipp/5.1/ia32/bin/linux32)
to LD_LIBRARY_PATH in your initialization script (.bashrc or similar):
LD_LIBRARY_PATH=/opt/intel/ipp/5.1/ia32/bin:/opt/intel/ipp/5.1/ia32/bin/linux32:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH
3) My Opencv is the most current version, say, opencv-1.1pre1
I did a comparison for the file "cxswitcher.cpp" of version opencv-1.1pre1 and that downloaded from
they are exactly the same.
Therefore, I strictly follow the steps proposed here
http://software.intel.com/en-us/forums/showthread.php?t=58909
Still can't load IPP. no idea of why it is so.
4) I then tried the most current open-cvs, instead of opencv-1.1pre1, still have the same problem.
Can anybody help me out of this problem??
Best Regards
JIA Pei
jiapei1001
Problem solved.
Add sharelib, instead of lib .
Now, working...
Quoting - jiapei100
Best Regards
JIA Pei
