6827 Discussions
Performace Issue - IPP 8.2.090 Crypto AES_CTR Mode
Deepak_B_
We have integrated with Intel IPP Crypto library version 8.2.090. We are using this library for AES Encrypt / Decrypt in CTR mode (for SRTP). Our target platform is a VMWare system running on Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz. Hence the application is linked with single threaded (st) version of libippcpv8.so.8.2 (optimized for Xenon platfor,) & libippcore.so.8.2.
Note: Our application already has thread pool implemented and hence we do not need to use the multi-threaded (mt) version of the libraries.
We compared the performance of Intel IPP crypto implementation of AES 128 bit CTR mode Encrypt / Decrypt with the aes_icm_ctr implementation in libsrtp (https://github.com/cisco/libsrtp/tree/master/crypto/cipher).
We observe that IPP crypto implementation is **slower** when compared to the open source implementation.  128 bit ippsAESEncryptCTR() takes ~125% of the time it takes for the corresponding implementation in the open source libsrtp code base - aes_icm_encrypt_ismacryp(). And that 128 bit ippsAESDecryptCTR() takes ~175% of the time it takes for the corresponding implementation in the open source libsrtp code base - aes_icm_encrypt_ismacryp().
Do you have any suggestions on how we can get Intell IPP crypto library to perform better on our target platform for AES in CTR mode ?
Below is how the routines are being invoked and these are the only methods that we are attempting to profile.
   #define SRTP_IPP_AES_CTR_BIT_LEN 16
    retStatus = ippsAESEncryptCTR(
            (const Ipp8u*)enc_start,
            (Ipp8u*)enc_start,
            enc_octet_len,
            stream->ipp_rtp_cipher_ctxt,
            ctr,
            SRTP_IPP_AES_CTR_BIT_LEN);
retStatus = ippsAESDecryptCTR(
                (Ipp8u*)enc_start,
                enc_octet_len,
                ctr,
Igor_A_Intel
Hi Deepak,
could you provide absolute numbers in cpu clocks per byte? I don't understand what 125 or 175% mean - 1.25x speedup or 2.25x. I'm curious why you see different ratios for encryption and decryption - for CTR mode of AES the same code is working... Also take into account that IPP functions are mitigated from any known sorts of attacks.
regards, Igor.
Deepak_B_
Hi Igor,
ippsAESEncryptCTR() takes 3958 usec to encrypt 32000 bytes of payload data while ippsAESDecryptCTR() takes 4888 usec to decrypt 32000 bytes of encrypted data. This is on a platform running VMWare VM configured to use 1 core of Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz.
On the Same platform the open source version (imlementation in libsrt - https://github.com/cisco/libsrtp/tree/master/crypto/cipher) takes 3465 usec to encrypt 32000 bytes of payload and 3867 usec to decrypt  32000 bytes of encrypted data.
Platform:
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 62
model name      : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
stepping        : 4
microcode       : 0x416
cpu MHz         : 2600.000
cache size      : 20480 KB
fpu             : yes
fpu_exception   : yes
cpuid level     : 13
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts mmx fxsr sse sse2 ss syscall nx rdtscp lm constant_tsc up arch_perfmon pebs bts nopl xtopology tsc_reliable nonstop_tsc aperfmperf pni pclmulqdq ssse3 cx16 sse4_1 sse4_2 popcnt aes xsave avx hypervisor lahf_lm ida arat epb xsaveopt pln pts dtherm
bogomips        : 5200.00
clflush size    : 64
cache_alignment : 64
address sizes   : 40 bits physical, 48 bits virtual
power management:
Igor_A_Intel
Hi Deepak,
did you perform a call to ippInit() function before a call of any other IPP processing function?
regards, Igor
Igor_A_Intel
Deepak,
below is an output from our performance system (you can find it in the standard installation in the "tools" subfolder - ps_ippcp) - you see, that for single thread and 3.5 GHz AVX CPU it takes 14 usec to encrypt/decrypt the 32K vector, therefore taking into account that you have 2.6 GHz CPU - I expect 14*3.5/2.6=~19-20 usec, but not 4000-5000:
CPU       Processor supporting Advanced Vector Extensions instruction set               4x3.49 GHz        Max cache size 8192 K
OS          Linux (2.6.32-279.el6.x86_64      x86_64)
Computer           nnlmdp312
Library  ippCP AVX (e9)   8.2.1 (r44077)   Oct  9 2014
Start      Thu Oct  9 18:57:30 2014
what kind of linking do you use - static or dynamic? what kind of library - single or multi-threaded? do you call ippInit() if static? could you provide an output from ippcpGetLibVersion() function?
regards, Igor
Igor_A_Intel
attempt #2 to insert the table failed...
Igor_A_Intel
attempt #3 function Parm1 Parm2 Parm3 Parm4 Parm5 Comment Clocks per Time (usec) ippsAESDecryptCTR 8u - 32768 128 128 nLps=4 1.5 e 14.1 ippsAESDecryptCTR 8u I 32768 128 128 nLps=4 1.5 e 14 ippsAESEncryptCTR 8u - 32768 128 128 nLps=4 1.5 e 14.1 ippsAESEncryptCTR 8u I 32768 128 128 nLps=16 1.5 e 14
